Ultra Low noise voltage regulator IC till 80Volts?
Old 18th April 2014, 03:09 AM   #1
rhythmsandy is offline rhythmsandy
Default Ultra Low noise voltage regulator IC till 80Volts?
There are couple of TI voltage regulators with noise floors as low as 3 to 14uV but the limit is upto just 35V after that there is another one with 100V but only for positive rail there is nothing for negative rail substitute.
Are there any other vregs with low output noise?
Old 19th April 2014, 12:50 AM   #2
RNMarsh is offline RNMarsh  United States
RNMarsh's Avatar
Can the 100v v-reg be turned upside down and run as a neg-v-reg?
-RM
Old 19th April 2014, 01:26 AM   #3
DUG is offline DUG  Canada
Here is another thread that rythmsandy started yesterday that contain a part number that goes to 36V input and has a negative regulator equivalent that is 16uV of noise. (the positive one mentioned is 4uV):
voltage doubler for TPS7A4700
Doug We are all learning...we can all help
"You can't stop the signal, Mal. Everything goes somewhere..."
Old 22nd April 2014, 02:20 AM   #4
djk is offline djk
R.I.P
djk's Avatar
Use split supplies and ground the positive output for the negative regulator.
Candidates for the Darwin Award should not read this author.
Old 22nd April 2014, 02:36 AM   #5
got the answer from other thread thank you the implementation is pretty similar to what you said..
Ultra Low noise voltage regulator IC till 80Volts?Hide this!Advertise here!
Ultra Low Noise - Ultra Low Impedance - Ultra big Problems! Stefan0815 Analog Line Level 2 14th January 2014 06:01 AM
Simple Low Noise Voltage Regulator? lxmyers Power Supplies 16 27th November 2011 08:24 PM
FS: 2pcs DEXA/NewclassD 7915 voltage regs, ultra low noise, different -VDC possible aircondition Swap Meet 1 18th August 2011 08:43 AM
Ultra low noise JFET voltage regulator Kochkurov Maxim Digital Source 6 25th January 2004 11:33 AM
