Help with ocillating amplifier !! - diyAudio
Old 13th April 2014, 05:53 PM   #1
Default Help with ocillating amplifier !!
Hi!
Lets take this from the begining...
At first i have to say i'm not write or speak English so well...
A friend gave me a sub woofer (Audio pro SUB+) that was stone dead when plugged to the mains.
I thaught it would be an easy one to fix, and started right on to trouble shoot the electronics.
This is a special amplifier design (ACE bass) and can only drive the specific driver it ment for.
* Transformer was no longer able to put out any voltage.
* both output transistors shorted.
I replaced the transformer with two toroid transformers with almoast the same spec, and new Output transistors.
Now i try to adjust the negative resistance, following the servicemanuals instructions. The amplifier ocillate and i can't get a stable output voltage.
The instruction... Set the amplifier in Trim mode ( jumper) turn level and filter adjustment fully clockwise. Connect a tone generator on the input an adjust it to 50Hz. Adjust output level on the generator so you can read 1 volt on speaker output no load. Connect a 8ohm resitsor to speaker output and adjust trimpot VR202 so you can read 6,27volt on speaker output.
What i get is a voltage from 6-11 volt up and down ocillating...
I need help !!!
Old 13th April 2014, 08:53 PM   #2
Send a message via Skype™ to overall feedback
What about resistors R216, R217 and R241?
Old 14th April 2014, 04:13 AM   #3
ostripper's Avatar
Yes , R241 and the op-amps seem to be a speaker impedance feedback circuit.
Most of the current returns to 0V through R241 , as well as producing
a small signal NFB for the IC.
I could imagine what the FB/phase would be without R241
The output stage is "super over compensated" (220pF) and has basestoppers.
I doubt it would oscillate itself without a very serious feedback issue.
Very interesting !
OS
Wanderer - my travels.... Facebook - davyjones lockre -
Old 14th April 2014, 05:20 AM   #4
Bonsai is offline Bonsai  Europe
Bonsai's Avatar
Is R241 ok?
Oh - I see OS already asked that! Damn, I'm just too slow to the draw today
bonsai
Amplifier Design and Construction for MUSIC! http://hifisonix.com/
Old 14th April 2014, 05:28 AM   #5
ostripper's Avatar
Originally Posted by Bonsai View Post
Is R241 ok?
Yeah , he could of damaged the IC with a shorted OP (and/or burnt R241).
He did not say what type of oscillation. What he describes is
"pumping" ,(a LF oscillation).
I commented as the circuit was new to me - I'll find a use for it .
PS - he should check the zeners + the IC.
OS
Old 14th April 2014, 09:15 AM   #6
I think it is likely that the failure of the output transistors has destroyed the drivers or the op-amp. Its worth checking the phase of the replacement transformers, if the secondaries are in series. This is the first commercial application of the op-amp based push-pull Vas circuit I have seen.
My blog:
Consort3's Blog | Just another WordPress.com weblog
Old 14th April 2014, 09:22 AM   #7
R216, R217 and R241 Are all messured to spec... IC201 is changed for a new one. C203,C204 checked as well.
I allso have to tell, when testing with 16ohm load its 100% stable output but with less voltage.. (ca 3volt) When i messure the voltage on the main smoothing caps at 8ohm load i notice a change of some volt upp and down, the same behavior as shown on the output. Are the transformer simly to smal!! ??
Old 14th April 2014, 09:48 AM   #8
OS
About the Zener, ZD201.. As it looks to me this Circuit adjust the gain for the IC102A to prevent overdriving the amplifier. Correct me if i'm wrong. (still in the Learning stage)
And how do i messure a zener?
Old 14th April 2014, 10:10 AM   #9
Do you have 50Hz connected?
Old 14th April 2014, 10:13 AM   #10
Yes, 50Hz sine wave
Motional feedback amplifier based on Philips 40 wats amplifier 1970s sanbadgujar Solid State 14 13th October 2013 01:35 PM
converting PA amplifier into symetrical class A son of Zen amplifier muddasirwaheedmalik Pass Labs 5 16th October 2012 04:01 PM
An amplifier to take to University - A small low power integrated amplifier monty78pig Solid State 33 31st August 2012 06:00 AM
Wanted: DIY amplifier builder with experience. I need a 0.7 ohm stable amplifier Audiophilenoob Swap Meet 34 16th May 2005 11:58 PM
Questions about how to decrease the PASS A-40 amplifier into a class AB amplifier. novtango Pass Labs 2 21st October 2002 01:50 AM
Copyright 1999-2017 diyAudio
