Hi guys im after a nice simple design for a preamp to got with the apox volume control setup.
Any ideas ? just needs to be clean - no balance or tone controls. Also if possible a pcb be avaliable I'm open to more complex ideas - but would prefer simple. ie not discrete ( woud be nice but pcb design etc is not my forte ) |
#2 |
Tall double non-fat
The High Quality Preamp from Elliott Sound Products seems to fit your criteria, and you can buy the PCB.
Folly befits a fool. |
#3 |
I looked at that one - but wasn't sure how to bypass the balance .
Buying from these guys would be great cause they are just up the road from my place
#4 |
Omit VR2. No balance control.
But note well Rod's comment about the effect of the pot on sound quality. |
#5 | |
But at the moment the attenuator and output can be found in a PDF file here .. Feel free to use it. |
#6 |
Nice!
Which microcontroller will you be using for the pot? Or can you connect a rotary encoder directly to that potentiometer chip? I'm trying to get started with programming og PIC's, but it's certainly not easy, when my only programming experience is with PHP... ![]() But I'm wondering - what would it require to do a balanced version of your pot-circuit? I'd need two pots, but how would I connect them to the PIC/rotary encoder? |
#7 |
Hi , actually i have a circuit diagram for the balanced too....
I will use ATmega8515 or ATmega16/32. depends on my memory needs. And they are programmed in "C" More to come... |
#8 |
Great, I'm looking forward to seeing it...
#9 |
The Balanced version is here : mirandp2-1.pdf
As you can see the two XWM8816 is connected in parralel on the SPI bus (MUTE,CS1,SDI,SCLK) if you want to control them individual you need to seperate CS1. You still use the same SPI interface. Only chip select is separated. |
#10 |
Great. I'll dig into this whenever I get around to making a PIC burner.
Have you thought about biasing the opamps into class A? With AD8620/AD8610 the improvement is minimal if existing at all, but with OPA627 there should be a noticable improvement. Btw - how many microcontrollers do you end up using for the whole preamp? |
| Preamp Design | steevo | Solid State | 8 | 10th October 2007 09:11 PM |
| HELP PLEASE - with preamp design | soundbadger | Tubes / Valves | 5 | 2nd October 2007 06:38 PM |
| Preamp PSU Design Help | DoomPixie | Tubes / Valves | 18 | 5th July 2005 02:08 AM |
| help with BJT preamp design | nobody special | Solid State | 0 | 24th March 2003 01:27 PM |
| Preamp design | Alex | Solid State | 13 | 11th October 2001 10:49 AM |
