Old 5th January 2004, 08:38 PM   #1
Send a message via Yahoo to mikelm
Default cancelling memory distortion ?
If a audio dual matched transistor pair is used at the i/p of a balanced amp and each half fed with the two differential phases of the i/p signal, will the alternate heating and cooling effects on each device cancel out due to their proximity.
can we assume that the two devices are close enough for this to occur ?
can anyone think of any drawbacks of such a scheme ?
would the cancelation cover all relevant frequencies ?
does anyone know about this kind of stuff ?
mike
Old 5th January 2004, 09:05 PM   #2
johnferrier's Avatar
Have you seen the following site (I happened on to it this morning). I think the author is a diyAudio member...
http://peufeu.free.fr/audio/memory/
JF
Old 5th January 2004, 09:10 PM   #3
yes Iv'e read most of it twice !
However I don't think that this idea is covered there
If it works it is a very simple remedy in a balanced approach
Old 6th January 2004, 09:56 AM   #4
Previously: Kuei Yang Wang
Location: Somewhere nice on planet earth where censorship of Ideas is frowned upon
Default Re: cancelling memory distortion ?
Konnichiwa,
Absolutely not, UNLESS the transistor are on the same chip and the chip has a low thermal intertia. I think there are way too many if's and but's in this to rely too much on this.
As a rule, the higher the frequency the lower thermal distortion effects as the thremal inertia of the actual semiconductor chip becomes relevant and limits temperature changes.
Sayonara
Old 6th January 2004, 10:25 AM   #5
Account Disabled
Default Re: Re: cancelling memory distortion ?
Sayonara
Not entirely. there are two "thermal effects" going on in a semiconductor component.
One is the steady state thermal heating. Let's say that you apply a constant sine wave, regardless of its frequency, the ohmic heating will reach an equilibrium after a period of time, and die temperature will stabilize at that point. the operating point of the component will, as such, shift depending on the signal. You will hear people talking about "thermal resistance / resistivity".
Another is the transient response of a device. the temperature of a device will go up and down with the signal, or being modulated by the signal. You will hear people talking about "thermal impedance" in those cases.
both effects are thermal-induced but its mechanism is slightly different.
Old 6th January 2004, 12:14 PM   #6
I was thinking of the SSM2220P and SSM2210P with dual devices designed specifically for audio i/p
I was thinking that the two devices would be physically & thermally quite close.
does any one know what this inside of these things are like ?
Old 6th January 2004, 12:29 PM   #7
jan.didden's Avatar
I don't know about these devices, but I do know that the similar LM394 dual consist of a chip of many (IIRC hundreds) of individual transistors, parallelled to form two transistors. The individual transistors are physically spread over the chip for two reasons:
1 averaging out the electrical characteristics for electrical matching;
2 idem for thermal matching.
This seems to be a standard technique, so I would expect (but don't know for sure) the SSM's to be similarly constructed.
Jan Didden
Old 6th January 2004, 06:31 PM   #8
The one and only
Nelson Pass's Avatar
This approach is standard in chip op amps, where the diff
transistors are made at the same spot, thus matching them,
and have the same temperature. Op amp performance
depends on such tricks, as the ability to select the components
on the chip is very limited.
Old 6th January 2004, 07:20 PM   #9
Thanks, this sounds quite encouraging. I'll go ahead and do some experiments.
The only further question is one of max current
All these devices quote 20mA as the absolute max
and the max voltage is around 30V
I want to use a higher current perhaps 35mA in the cct I am thinking of but only 7 volts.
Given this very low voltage will a higher current damage the devices even though the power is far below the max
If this is the case, I do not understand why this would be.
or...Will I have to paralell them ?
Can anyone shed some light on this ?
Old 6th January 2004, 07:57 PM   #10
Faber is offline Faber  Italy
Send a message via ICQ to Faber Send a message via MSN to Faber
I've tried to modify the Balanced Line Stage with the suggestions depicted in that site and the result is great in terms of stage and darkness of the scene.
In some particulars the original design is better (armonics, warm) but they are quite negligible.
I'm building a second original-design BLS, so to make more in deep analysis.
Anyone else tried something similar?
Happy new year!
Fabrizio
Aleph (Single Ended) + Larvadin (no Memory Distortion) = Ultimate Aleph? tiefbassuebertr Pass Labs 17 9th January 2012 02:10 PM
Memory Distortion? and some new beginnings. vynuhl.addict Solid State 144 8th January 2012 02:53 AM
Hum cancelling scheme? slor Tubes / Valves 15 24th January 2008 12:07 AM
Memory distortion, crap or serious? Pjotr Everything Else 15 11th March 2004 05:48 PM
Lavaradin Amp and "Memory distortion"... Lisandro_P Solid State 26 18th September 2003 02:37 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
