cyrus 8v2 with buzz after 2 hours - diyAudio
Old 7th April 2014, 02:46 PM   #1
silence is offline silence  Denmark
Default cyrus 8v2 with buzz after 2 hours
my cyrus 8vs2 have started make a buzzing sound. It only starts after the amplifier has been playing for 1-2 hours. It is most obvious from the tweeters but can also be heard from the midtone. If I change input on the amplifier to an unused input and back again it disappears for a minute or two and then reappears. It is not a very high buzz, but definitely irritating even when playing music a moderate sound level. It should be mentioned that I use very sensitive speakers (95 dB). The buzz has not always been there.
Any ideas what could be broken inside?
Old 7th April 2014, 04:20 PM   #2
There's no free information out there for late model Cyrus amplifiers so it won't be easy to get specific help for that model. I would seek the agent's advice to get a professional opinion for such high sensitivity speakers. Such noise may go unnoticed with conventional types of say, 88dB sensitivity. Considering the long period before the noise appears, it's likely the fault is induced by heat and this can be found in a few things like caps, semiconductors, soldering and other heat fatigue connection problems. Really, that is for a good technician to undertake with instruments in those compact and fussy models.
I say this because I have earlier models in the same case myself. It's not at all simple getting into those, let alone work to the standard of the manufacturer.
Ian
HELP, repaire Cyrus LFAU similar to Cyrus II ccheung Solid State 15 3rd March 2016 12:08 PM
End resistors Cyrus 8v2 mod Theduboracle Solid State 3 1st February 2014 07:06 PM
buzz buzz... probleme with VSPS 6ri.l Analogue Source 0 19th August 2010 04:41 PM
WTB Cyrus 1 or Cyrus 2 amplifier monstertrucker Swap Meet 0 20th November 2008 01:04 AM
Melos triode and computer as source: BUZZ BUZZ BUZZ zigo3 Tubes / Valves 4 28th November 2007 02:11 AM
Copyright 1999-2017 diyAudio
