What can cause noise in this design? - diyAudio
Old 3rd April 2014, 04:13 PM   #1
Mihkus is offline Mihkus  Estonia
Mihkus's Avatar
Default What can cause noise in this design?
I built an amplifier, just for fun...
Used 2 2SC5200 and one 2SC.. something Should be driverstage NPN
The circuit:
I know its ultra simple only 9 components... But when i adjust feedback more than 500 ohms it starts humming...
Old 3rd April 2014, 10:25 PM   #2
Send a message via Skype™ to overall feedback
The circuit is not properly designed. It can not achieve a stable quiescent current. It have no feedback divider. Collector load from emitter is against voltage amplification logic. Hum comes probably from supply .
You have to measure few voltage points to see that it can't work.
Old 3rd April 2014, 10:31 PM   #3
nigelwright7557's Avatar
Look up class AB amplifiers for some good examples.
Old 4th April 2014, 02:50 AM   #4
The circuit:
Although it has some design issues. What happens and what do you get audio wise with feedback less than 500 ohms ?
Cheers / Chris
Old 4th April 2014, 02:32 PM   #5
Mihkus's Avatar
That "VAS" is 2SC1826 and damn, after few modifications it sounds totally fine.
Even if it has 280R input resistance... lol
Added 100R resistor to 2SC1826's emitter, used fixed resistor on feedback
And changed that 2,2k trimmer to 1k and turned it on almost half way and theres 8 volts across the output capacitor and a 33pF capacitor across feedback resistor without a reason...
That laptop charger i used had that noise, I dont know after adding 2,2R and very low resistance capacitor after it it starts up and the weird humming noise is gone...
Cant set gain too high it picks up everything going thru the air...
Low noise Preamp design advice for complete noob Hix Chip Amps 6 3rd January 2014 09:03 PM
Low noise amplifier design fundamentals GlidingDutchman Analogue Source 5 25th May 2008 05:14 PM
differential design, common mode noise rejection Sebastiaan Solid State 0 17th April 2006 09:16 PM
Noise Cancelling Headphoneamp design. Garbz Solid State 0 12th February 2004 08:34 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
