#41 | |
Did you compress it? Usually there are troubles with attachments > 5MB, splitting the file, if possible, will help. Anyway I have another email, pirobrothers@tin.it or andypairo@supereva.it Let me know if these work. Cheers Andrea |
#42 | |
I can try to upload them to my "web disk", but don't know if it can be properly accessed.. can someone try hitting on the "www" button under my posts and tell me what he can see/download? Cheers Andrea |
#43 |
I can see something like this:
BackAngle2 .jpg 12/11/03 - 9.53 94.1 KB FrontLit11 .jpg 12/11/03 - 9.53 83.0 KB FrontLit21 .jpg 12/11/03 - 9.53 81.3 KB SideAside .jpg 12/11/03 - 9.53 66.4 KB Symamp .JPG 12/11/03 - 9.53 570.4 KB Seems like the bigger files are invisible!?.... |
#44 |
You were too fast....
I was still uploading them.Try downloading one and tell me if it works. Cheers Andrea |
#45 |
Hello, I tried from my PC at work and it only works the second time I try.
For the non-italian speaking you must check the box at the left of the file and then push the "scarica" (=download) button. Cheers Andrea |
#46 |
Yes....I can see the files :-)
I tried to download the biggest (AW-65), and the file was OK. Lyra |
#47 |
Perfect... now I only have to understand which part belongs to which amp... I'm afraid there was a real mixup... for sure the cabinet and the delay belong to the ampliwire 65, the other parts are to be identified yet
If I get my hands on thet guy... Cheers Andrea |
#48 |
According to my oppinion, and the pictures the amp is an old AW-65, but the amplifier-boards, and the trafo is from an AW-120 !?.
To be 100% sure you should have the schematics regarding the AW120...but that one I dont have.... If you decide on changing the trafo to a trafo that is more suitable ragarding tha SOA of the output-transistors, i might be interested in bying the AW-120 trafo. I got an old AW-100 with trafo-hum....quite irritating !!! I think the AW-120 could be able to adapt the trafo from the 120 watter. Slightly higher voltages, but think that could be overcome. Send me a mail when you have decided, and what you eventually how much money you want for it !? All the best. Lyra |
#49 |
I agree with you but what is strange is that the board has only provision for 1 pair of output devices, unless they are a particularly rugged type.... it seems I will have to remove all these screws and take a closer look....
Cheers Andrea PS About selling.. the amp is not mine, but I can ask... |
#50 |
My bet is that the output-BJT's is same as the newer AW-60FTT whitch uses 2SC3281/2SA1302 BJT's
Maybe MJL4281A (NPN) and MJL4302A (PNP) could have been used instead. They can stand a little bit more power i think, but not enough to last with tough loads (4ohm etc.), and 46V supplyvoltage. But who knows, you might be lucky !?
| Electrocompaniet ECI-4??? | kimschips | Solid State | 13 | 26th April 2013 09:11 AM |
| Hello from an Electrocompaniet Fan | PrimeCase | Introductions | 10 | 25th September 2012 01:17 PM |
| DAC electrocompaniet ecd tweak? | ffarges | Digital Source | 1 | 17th December 2008 11:28 AM |
| Electrocompaniet AW 250 AMP. | hogue | Solid State | 1 | 1st March 2004 05:48 AM |
