Old 7th January 2004, 11:08 PM   #11
Tube_Dude's Avatar
Originally posted by Andypairo
I checked again and... there are no power resistors !
It's probably the first design I see that doesn't use 'em...
Cheers
Andrea
Hi andrea!
The legendary NAD 3020 doesn't also use emiter resistors...
Ci vediamo!
Jorge
Old 8th January 2004, 05:40 AM   #12
Jan Dupont's Avatar
Send a message via MSN to Jan Dupont
What is the name of the output devices???
Free Schematic and Service Manual downloads www.audio-circuit.dk, Company: www.dupont-audio.com, Joint venture: www.DupontMantra.com
Old 9th January 2004, 05:21 PM   #13
Andypairo's Avatar
Probably tomorrow I'll unscrew the pcb from the heatsink and will be able to read their name.
They are T03-p devices, and are mounted under the PCB
Cheers
Andrea
Old 14th January 2004, 01:48 PM   #14
Andypairo's Avatar
Angry Bad news, what has gone wrong?
I removed all the solderings on the pin-strip connectors and made a matching PCB with local bypass capacitors (1000uF) on the supply rails.
This cured the nasty oscillation that occurred before.
I also removed the input capacitor coupling, connecting the "POS" pad to the RCA input and the "NEG" to GND.
Attaching my signal generator and a dummy load everything worked fine, so I took it to my friend's house.
First we connected it after his preamp and everything worked fine, he liked it and said it sounded much more similar to his EC-2 integrated amp.
Afte that he wanted to test it with direct connection to his Marantz CD14, which has a variable output.
On switching on there was a buzz on a speaker with a woofer bumping-out (symptom of DC on the output), we switched the amp off and then on again and could listen to some music.
The next time we switched it on the DC on outpuw was still present, so I looked at the inside and found a loose soldering on one supply (driver).
I re-soldered the joint but this didn't cure the problem, so I took the amp home again.
Here, to my surprise, it works flawlessly.
I suspect the CD player output, but how can be possible that a 2500 € player has DC on the output?
Any suggestions??
Cheers
Andrea
Old 14th January 2004, 02:42 PM   #15
Workhorse's Avatar
Exclamation Reply
Most marantz cd players are direct coupled at output , they donot use coupling caps on their outputs
It's a fruitless endeavor to try and educate a fool that rejoices in ignorance
Old 14th January 2004, 02:55 PM   #16
Andypairo's Avatar
I suspected that, but didn't think that this could cause any harm... after all the amp has a DC servo on board! (or maybe is the servo faulty?)....
Cheers
Andrea
Old 14th January 2004, 03:07 PM   #17
stigla is offline stigla  Norway
Have you tried the Electrocompaniet Forum?
http://www.electrocompaniet.com/disc/default.asp
I have no experience with this forum, but maybe someone can help you out.
I have never heard of a AW65 though, Just AW60 (whitch is a descendant from the AW120 monoblocks...)
stigla
Old 14th January 2004, 05:03 PM   #18
Andypairo's Avatar
Default Some pics, just to identify it...
I took some pics that might help identifying the amp...
The main board with the auxiliary PCB I used to avoid soldering on the connectors and to place some bypass caps
Old 14th January 2004, 05:05 PM   #19
Andypairo's Avatar
The protection board (that only acts as delay since the connector is not attached...)
Old 14th January 2004, 05:08 PM   #20
Andypairo's Avatar
The front panel.. the red writing says "Ampliwire 65 2 Channel High permformance Audio Amplifier"
Electrocompaniet ECI-4??? kimschips Solid State 13 26th April 2013 09:11 AM
Hello from an Electrocompaniet Fan PrimeCase Introductions 10 25th September 2012 01:17 PM
DAC electrocompaniet ecd tweak? ffarges Digital Source 1 17th December 2008 11:28 AM
Electrocompaniet AW 250 AMP. hogue Solid State 1 1st March 2004 05:48 AM
Copyright ©1999-2013 diyAudio
