MOSFET based TRANSFORMER COUPLED CAR AMP
Old 4th January 2004, 11:58 PM   #1
Workhorse is offline Workhorse
Workhorse's Avatar
Arrow MOSFET based TRANSFORMER COUPLED CAR AMP
Schematic
Old 5th January 2004, 06:59 PM   #2
Kashmire is offline Kashmire  United States
Fascinating!
I see you are driving an interstage transformer with a single-ended MOSFET with a resistor load. The output stage is similar to this thread, with the exception that the circuit below operates in source-follower configuration.
http://www.diyaudio.com/forums/showt...788#post289788
I have many comments:
- Why use a resistor load on the single-ended MOSFET driver? Why not use a choke load or a constant-current source?
- Your interstage must drive a lot of capacitance. Have you considered changing your output stage to source-follower? Your output stage will have no voltage gain, but the gate capacitances will be very small. Would your driver stage be able to deliver enough voltage?
- What is the windings ratio of the interstage transformer?
- What is the ratio of the output transformer? This transformer must be large (at least by car audio standards). Also, you are really trusting the bias to stay stable. Otherwise, you'll have a DC offset in the OPT.
- I'm assuming that the sources (and the zener) are grounded in the output stage ...
Old 26th January 2004, 10:57 PM   #3
dmfraser is offline dmfraser  United States
Default Amp schematics
Find more schematics at www.schematicsforfree.com
Dan Fraser
MOSFET based TRANSFORMER COUPLED CAR AMPHide this!Advertise here!
Class A2 Direct MOSFET Coupled SE Michael Koster Tubes / Valves 178 15th June 2018 05:16 PM
6sn7 direct coupled and transformer coupled neazoi Tubes / Valves 3 23rd May 2008 03:30 PM
6922 transformer coupled Andersen Tubes / Valves 12 9th April 2008 02:47 AM
Power follower class A Mosfet DC coupled. Mr. Steve Solid State 30 15th February 2006 06:04 PM
Transformer coupled linestage Panelhead Solid State 10 18th October 2005 09:57 AM
