my latest amplifer
my latest amplifer
Old 4th January 2004, 09:34 PM   #1
Easyamp is offline Easyamp
Easyamp's Avatar
Default my latest amplifer
I thought I'd share my latest almost finnished amp with all.
It's basicly a p3a front-end with constant current instead of the boot strap and then into a tip122 quasi output but at a lower voltage so I could use 2n390X throught out.
It was made with parts on hand so some values are less then optimum like the 33p cap in the front-end should of been larger.
Old 4th January 2004, 09:47 PM   #2
Easyamp's Avatar
Default Shcematic
Here's the shcematic.
Old 4th January 2004, 10:03 PM   #3
millwood is offline millwood  United States
Account Disabled
it looks good.
one observation: since you alread have the ccs there, why don't you just add one transistor so that the input stage also has a ccs?
Old 4th January 2004, 10:44 PM   #4
Easyamp's Avatar
Good point, I don't know.
I have the student version of pspice so 10 bjt or less but I could of done the front end seperate from the rest to work out genral values and soft analisys.
I think I'll revise.
Old 4th January 2004, 11:24 PM   #5
Workhorse is offline Workhorse
Workhorse's Avatar
Arrow Reply
u can use Circuitmaker Student edition for 50 device limitation
Old 5th January 2004, 12:02 AM   #6
Account Disabled
by the way, what does R18 (220ohm) do for you?
Old 5th January 2004, 01:15 AM   #7
Easyamp's Avatar
I only had a 500 ohm pot on hand and this would not work. So I added the 220 ohm r to get me into the 500~700 ohm range which would get me a fair amount of offset control and get the A class vas to work properly.
Old 5th January 2004, 01:22 AM   #8
Account Disabled
but isn't it shorted by the wiper? maybe you wanted to put it above the trimmer, depending on the desired value of the resistor / trimmer combination.
Old 5th January 2004, 02:08 AM   #9
Easyamp's Avatar
r18 is on the otherside of the trimmer, it's just a typo I made recreating the circuit in eagle to post online.
Old 5th January 2004, 03:48 AM   #10
Easyamp's Avatar
Default Revision
Here's the reivsed.
I like to to keep simple things simple, but Millwood if your reading, do you think by using a shared ccs in the df stage I will be introducing more noise by the flucutuations caused by the vas, than I can wrinkle out by the increased gain of the new df's ccs vs negative feedback?
I have one made already, I'll make another with the revisions and see which looks good.
my latest ampliferHide this!Advertise here!
DBX BX-3 Amplifer Woes...What is going on? EchoWars Solid State 13 6th April 2008 04:03 AM
Amplifer calculation irdeto Tubes / Valves 6 19th February 2007 09:00 AM
Amplifer HELP!!!! Pate Solid State 0 21st November 2005 05:16 AM
q on amplifer inputs. theChris Solid State 1 12th July 2003 06:51 AM
Copyright ©1999-2017 diyAudio
