high performance regulated supplies for power amps
Old 4th January 2004, 05:51 PM   #1
jez is offline jez  United Kingdom
Default high performance regulated supplies for power amps
Hi all,
I am new to this site and will first of all apologise if my shearching has not been as good as it could be in regard to previous threads,however, I cant' find a great deal of info on really good regulated supplies for power amps. What I have in mind is something of similar performance to the Jung/Diddens, Sulzer designs but this does not seem to exist !,most designs I have seen are either far to slow or have far to high output impedance.
The obvious solution would be a Sulzer type with level translator which offers maybe x3 gain after the op-amp followed by the pass transistor/darlington/mosfet but this would almost certainly oscillate unless it was compensated to the point where it was no faster than an LM317 with series pass device...
Maybe such luminaries on this site as ALW or Janneman have some pearls of wisdom on the subject.... maybe I'll have to design a high speed,high voltage discrete op-amp unless someone knows of a suitable design elsewhere
Jez.
p.s I know many feel that simple capacitor supplies are superior but I have a suspicion that a suitably quick,low impedence,stable regulator would surprise a lot of people !.
Old 4th January 2004, 06:36 PM   #2
andy_c is offline andy_c  United States
Banned
Default Re: high performance regulated supplies for power amps
Here's a 90 Volt version of the "super reg" topology. Watch the dissipation in some of the resistors! Also the dissipation in the shunt reg for the op-amp is too high to use a TO-92 for the TL431. You'll need a DIP or surface mount package here.
I haven't built this yet, but stability and recovery from transient load currents have been simulated to death. A key issue in the stability is that it depends strongly on the non-ideal characteristics of the 100 uF load capacitor. Both the series resistance of around 0.25 Ohms and the series inductance of ~30 nH come strongly into play here. The load capacitor's series resonance is at about 93kHz which forms a low-Q notch filter which helps stabilize the circuit. Don't put a high Q 0.1 uF capacitor for a load! It will oscillate.
There's been lots of discussion of this and related topics in this thread: http://www.diyaudio.com/forums/showt...937&highlight=
It's not capable of powering the output stage of a power amp, but it's suitable for MOSFET power amp designs in which the output stage supply is separate from that of the rest of the circuitry.
Old 4th January 2004, 06:39 PM   #3
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
An interesting option would be to use a couple of gainclones for each channel, DC coupled, putting a DC on the input that gives the required DC (+ or - supply) at the output as the supply. That will take care of stability problems which, as you say, will be probable and expensive. The gainclone should be stable in this application, using the customary zobel at the output.
I am pretty sure that you can put say 10.000uF at the gainclone's output to supply transient load currents. The inherent current limit of the gainclone would protect it at startup.
Since you can set the raw supply for the gainclone just a bit (say 5 volts or so) above the supply required, SOA wouldn't be an issue.
For a stereo power amp you would take 4 gainclones to have a separate +/- supply for each amp. You need only two raw supplies for the gainclones. Suppose your power amp need +/- 30VDC. The gainclone supplies would then be say +35VDC and gnd for the pos supply, and -35VDC and gnd for the neg one.
(I also like the irony of using a gainclone just to power a power amp, but that shouldn't bother you)
What do the other experts think about this idea? Am I off my rocker, or what?
Jan Didden
Old 4th January 2004, 07:42 PM   #4
Andy C,
Your mods to the super reg look most interesting !, I had'nt thought of losing the voltage across those zeners whilst keeping a low impedance drive for the next stage with minimal phase shift as I would think this would do.It could be interesting to replace Q4 with a push-pull follower with a touch of forward bias and then change Q5 for a low-on-resistance P-MOSFET of suitable current rating(the op-amp inverting and non inverting inputs would have to be reversed to maintain the correct feedback polarity). If this proved to be stable, I suspect this could be as close as I am likely to get to the ideal power amp supply, especially if a much faster op-amp remained stable and in conjunction with remote sensing.
I also found the output capacitor to be critical in high performance regulators, simulation shows oscillation with ideal output cap which can be tamed with a small series resistance, about 0.007 R was about optimum in my simulations of other , lower voltage regs (tend to look inductive at output).
Jan, I dont' know what a gainclone is yet !, there seems to be many threads on the subject but non of the ones I have seen so-far shows a diagram or explains exactly what peole mean by "gainclone", I'm sure further searching will produce enlightenment on the subject. I am,however,trying to avoid solutions which rely on a huge output cap to supply load transients and to give low ac output impedance.... or am I totally misunderstanding some subtlety of your approach here?.
I will check out the above link to an earlier thread.
Thanks for the ideas and "watch this space" as they say !
Jez.
Old 4th January 2004, 08:03 PM   #5
millwood is offline millwood  United States
Account Disabled
Jan Didden
no expert but I think the gainclone idea should work.
However, would the reverse be true? Has anyone tried to use a regulator as amp? either a linear regulator or smps regulator?
Jez.
gainclones are IC-based amps. gainclone ICs are usually LM chips (LM3875 and 3886) or OPA (541/549 etc.). some also use TDAs as well.
Old 4th January 2004, 08:14 PM   #6
Magura is offline Magura  Denmark
Magura's Avatar
How many A would it be possible to pull out of a gainclone chip?? At what voltage??
Magura
Everything is possible....to do the impossible just takes a little while longer.
www.class-a-labs.com
Old 4th January 2004, 08:24 PM   #7
JOE DIRTŪ is offline JOE DIRTŪ  Canada
JOE DIRTŪ's Avatar
good concept guys....I did utilise a LM12cl in a regulated high current supply....the only problem was the cost....the chip amps are far cheaper to use thus become a more viable solution
Old 4th January 2004, 08:44 PM   #8
Account Disabled
Magura
those chips can usually do 50w, and current limited to 6 (lm3875) to 8 or 10amps (opa). they are powered by +/-42v rails and dissipate 120w (lm3875).
Old 4th January 2004, 08:54 PM   #9
sam9 is offline sam9  United States
sam9's Avatar
Keep in mind that some writers on the subject such as D. Self contend that since a regulated power supply neccessarily involves a negative feedback network, using one with a power amplifier which also has a negative feedback network has the may cause serious problems. Potentially the two NFB cicuits could cause oscillations as they react to each other.
I can neither affirm or contradict the above assertion from my own experiences. I just think anyone contemplating the the use of a regulated PS with a power amp should be aware that the concern exists. There may well be circumstance specific to individual situations the either increase or decrease the likelyhood of a problem ocurring.
Old 4th January 2004, 09:03 PM   #10
Yes, I had realised that a gainclone is a chip based power amp,it was as to how it differs from a standard application note design in such a way as to be called a gainclone that I am unsure of, I should have explained my self better...
I would have thought that a "power op-amp" solution, which is what is being suggested here, would not have the slew-rate,gain or GBP to rival the super regulator.
As the type,quantity and make of smoothing caps seems to have such a profound effect on the sound of an amp, and as they are most definately in the signal path of the output stage, it seems to me that if we could replace them with something better that would be A GOOD THING. The reg would need to have very low output impedance and be faster than the amp it was powering, I reckon that using slow error amps and following them with huge capacitors is defeating the point ! (easy for stability though)
Jez.
high performance regulated supplies for power ampsHide this!Advertise here!
regulated power supply for high powered amps. marchel Solid State 14 5th March 2009 09:00 AM
About high voltage regulated power supplies wd40 Tubes / Valves 4 25th March 2004 03:16 AM
Regulated Supplies in Tube Amps runeight Tubes / Valves 88 2nd October 2003 04:01 PM
Regulated Power Supplies for Low Power Amps PTL60 Solid State 18 6th February 2002 06:24 AM
Copyright ©1999-2017 diyAudio
