#81 | |
Cheers Andrew....
#82 |
Hi Kimberlator
greetings thanks thanks at least now i know it works very kind of you to keep us informed warm regards andrew lebon
[image] |
#83 | |
Whenever i have the time i'll post some pics of the last stage and monstruous psu i've built for this amp. Have a great day Andrew, thanks for the quick reply... Paul.
#84 |
yes WORKHORSE DESIGNS ROCK was thinking of this monster for a long time its for fun
hes in THE LEAGUE OF EXTRAORDINARY GENTLEMEN ill finish it soon warm regards andrew lebon
[image] |
#85 |
You're right about that, seems like someone from outer-space give to him such knowledge, very electronics-skilled guy, the best part around this is the fact that he shares his brain-database with us and on top of that he helps everybody in anyway he can, no matter the level of difficult or nature of the issue to discuss, he always has the correct answer, great asset to DIY community, as well as other very skilled members of course, wish you the best luck on your project Andrew, Best Regards, Paul
#86 |
I have a bunch of diy amp & pre-amp schematics that i've found on the net, just in case you need something alike, i can post here to open discuss, let me know.
Take care man... Paul. |
#87 |
![]() ![]() ![]() Hi Kimberlator greetings please can you tell which schematic you made this is the one with 560 ohms and 38k in input section this pcb is for trial run only so only one pair mje15032 33 warm regards andrew
[image] |
#88 |
Hello,
please i need to design a CMOS LNA. can any1 help me out with the circutry.i'll be using multism. Thanks |
#89 | |
Well, i've made the High-Power Version, the one with 12 TO-3 MJ21194 devices per rail, and, as stated before, i've made it salvaging other amps, just to verify if it's actually work or not, since seems to be some temp issues with the design, as well as some resistor values that need to be changed in order to get it work, please note that you certainly will need to stick pre-drivers on a heat sink, as well as the ones on the VAS, they actually reach unsafe temps if not attached to a heat sink, and remember that the "Diode-Connected" transistors to be placed on main heat sink, as they are the "Heat Tracking Devices". Good luck Andrew, Paul
#90 |
Thats very old design of mine.
As Paul already said, the diode connected trannies must be attached to heatsink in order to get proper heat tracking. To enhance the low level signal clarity, put one more diode connected transistor in series with other two already in the schematic and set the trimmer accordingly to get 20mA idle current in output devices.
It's a fruitless endeavor to try and educate a fool that rejoices in ignorance
| Hi! And I built one too... | The RB | Chip Amps | 4 | 13th March 2009 09:12 AM |
| i built these a while ago and | roystr | Full Range | 11 | 10th November 2005 12:49 PM |
| Who has built their own? | markp | Solid State | 42 | 29th June 2004 09:42 PM |
| Anyone built this amp? | JojoD818 | Solid State | 26 | 19th August 2003 11:32 AM |
