Has any one built this 1KW amp? - Page 6 - diyAudio
Old 18th January 2004, 07:34 PM   #51
Matttcattt's Avatar
in practice (i was about to say "in theory"), what is the highest voltage rails you could have (DC)?
230vAC x 1.41 = 324.3vDC
using 2 seperate mains feeds, you could get +/-324vDC. this would be okay with 400v output devices, but could you get other components to work at this voltage?
If it aint broke, don't fix it. If it is broke, fix it.
If you can't fix it, take it apart and see how it "worked".
Old 18th January 2004, 08:17 PM   #52
Account Disabled
with +/- 324v DC, you are talking about potential voltage drops on the output devices of 324vx2=650v before any safety factors.
Realistically, you are probably talking about 1000v Vce/Vds devices. they are probably difficult to find and you may have to parallel a lot of them to drive 8ohm speakers,
Old 30th January 2004, 10:26 AM   #53
Workhorse's Avatar
Arrow Commentable Thoughts
Hi Samuel Jayaraj
How about ur project is going.
Doing well or not????
Ampman
Old 30th January 2004, 02:01 PM   #54
Duo is offline Duo  Canada
Duo's Avatar
Send a message via ICQ to Duo
I think there's a way you can cascade a set of transistors vertically, so that they can stand more voltage all together.
I rarely see this used in audio, but I know that it's been done.
At least it's a relatively useful way to make 250V transistors work in a 650V amplifier.
-- Duo, W1ngs, VA7MON, and lesser known handles. --
-- http://www.w1ngselectronics.com -- My Work and Projects --
Old 30th January 2004, 06:24 PM   #55
Did it Himself
richie00boy's Avatar
Default Burn up?
Hi amp_man_1
I like your schematic, but I notice that the bias voltage is set only using a pot, hence there can be no thermal tracking. Isn't this unwise with such a high power design and BJTs?
Old 30th January 2004, 08:16 PM   #56
Default 1000W RMS Power Amp
As someone who builds 1000W amps every day, I have had spectacular resilts with the ICEPower modules from B&). The 1000A costa us less than US$100.00 a unit.
As well, the 1000ASP is available to us for under US$200.00 and it includes a regulated switching 120/240V Power supply. Plus, the 1000ASP power supply has enough power capacity, it can drive a 1000A module, giving you 2000W of sub woofer power.
Alternately, it can drive 2 of the 500A modules to give you plenty of mid and high on a tri-amp system.
The prices are 100+ OEM prices. You will have to lookaround to see who may sell them. See:
http://www.powerhouse.bang-olufsen.com/sw1022.asp
Dan Fraser
Old 30th January 2004, 10:08 PM   #57
Matttcattt's Avatar
maybe i will re-write my question. what would be the highest rail voltage (DC) that you would use?
Old 31st January 2004, 02:29 AM   #58
Workhorse's Avatar
Default Re: Burn up?
Originally posted by richie00boy
Hi amp_man_1
Sir , The thermal Tracking is very well performed by diode connected transistors which are mounted on heatsink.
If u insist , I can also put a Vbe multiplier using transistor.
Ampman
Old 31st January 2004, 05:05 PM   #59
Did it Himself
Thank you amp_man. I would have thought that a Vbe muliplier would be a better way to do it than the 2 diode-connected transistors + pot?
Also, why is Q3 and Q4 on the o/p stage made from paralleled devices? A single device would easily handle current required, I would think.
Old 1st February 2004, 09:33 AM   #60
Workhorse's Avatar
Hey man
The parallel drivers play their role when someone is driving 2 Ohms load at low frequency , therefore for ample current drive requirements the paralleling is required.
Ampman
Who has built their own? markp Solid State 43 3rd August 2014 09:10 AM
Hi! And I built one too... The RB Chip Amps 4 13th March 2009 09:12 AM
i built these a while ago and roystr Full Range 11 10th November 2005 12:49 PM
Anyone built this amp? JojoD818 Solid State 26 19th August 2003 11:32 AM
Copyright 1999-2017 diyAudio
