Has any one built this 1KW amp? - Page 5 - diyAudio
Old 14th January 2004, 04:43 PM   #41
Peter,
It am sure you know what you meant, but I saw a risk your
phrasing could be misinterpreted as saying that it really isn't
dangerous, but just a forum rule. I wanted to clarify so nobody
gets the wrong impression here. It wasn't meant to pick on you,
and I forgot to point that out. Sorry. I just wanted to try
explaining why it is dangerous.
Old 14th January 2004, 04:47 PM   #42
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
I am well aware of the danger of that, and I would never recommended to use such setups (when device is powered directly from mains). I also realized my incorrect wording and that's why I explained/corrected it.
A moderator should always be an example of correct safety practices, I know that too
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 14th January 2004, 05:04 PM   #43
Matttcattt's Avatar
sorry to cause all the fuss. i understand the dangers of mains. i did not know that this was a forum rule, i will re-read the rules now.
would it work with +/-115vDC using an isolation transformer (1:1 windings) from the mains?
5000W with +/-115v is about 20A isnt it?
If it aint broke, don't fix it. If it is broke, fix it.
If you can't fix it, take it apart and see how it "worked".
Old 14th January 2004, 08:41 PM   #44
Account Disabled
Question About This Amp
This looks like a good strong power amp and i will try to make one prototyope.
By the way.... - amp_man_1 - is form your country PUNJABI MC ??? You know...songs....like JOGI and Mundian To Bach Ke ???
Silly question a ?
Old 14th January 2004, 09:41 PM   #45
Banned
Send a message via MSN to SkinnyBoy
did you know, that first off that transformer would still be huge... second when rectifying AC to DC you times the voltage by 1.41 giving you +-163 volts, and thirdly, you need a centre tap...
Old 15th January 2004, 12:14 AM   #46
Eh, well not, if you add the centre tap you suggest you rather
get +/- 82 V (or whatever is is, too lazy to calculate it now).
Old 15th January 2004, 03:12 AM   #47
Workhorse's Avatar
Arrow Reply
hey drafence u seems to me as INDIAN.
I know PUNJABI MC very well!
NI tu hunne hunne hoi muteyaar mundiyan ton bachke rahi
aiwe kari na kise de naal piyar mundiyaan ton bachke rahi
HEY dudes this above written was punjabi language song!
Happy amping!
Old 15th January 2004, 11:30 AM   #48
Send a message via ICQ to PicancoNet Send a message via MSN to PicancoNet
Default Re: Has any one built this 1KW amp?
Originally posted by VT Calais
Does anyone have any experience with
THIS or any other 1KW amp?
Where is the scheme ?
Sounds Goods
Old 15th January 2004, 11:52 AM   #49
Coulomb is offline Coulomb  England
Coulomb's Avatar
Default Re: Re: Has any one built this 1KW amp?
Anthony Holton only made the AV800 available in PCB form as far as I know. I have built up a few of the AV800's and they are nearing completion.
Old 18th January 2004, 09:36 AM   #50
Workhorse's Avatar
Default Reply
How about using some MJL21196 At output stage!
Who has built their own? markp Solid State 43 3rd August 2014 09:10 AM
Hi! And I built one too... The RB Chip Amps 4 13th March 2009 09:12 AM
i built these a while ago and roystr Full Range 11 10th November 2005 12:49 PM
Anyone built this amp? JojoD818 Solid State 26 19th August 2003 11:32 AM
Copyright ©1999-2017 diyAudio
