Has any one built this 1KW amp? - Page 26 - diyAudio
Old 3rd August 2013, 05:14 PM   #251
Aniket is offline Aniket  India
Aniket's Avatar
Originally Posted by Aniket View Post
Just a simulation in multisim.
Originally Posted by Krisfr View Post
The front end looks like the Honey Badger design, do you have just a schematic?
It's just a modification of my working amp, a humble 250W@4ohms.
Simple 100W power amp
Originally Posted by a.wayne View Post
How are you going to get 2400watts@2ohm from a 2.5kva transformer....?
Serious simulation cowboys ...
it's pretty obvious, the transformer size is mentioned for 4 ohms load.
Old 20th September 2014, 04:10 AM   #252
kimbal is offline kimbal  Australia
kimbal's Avatar
Originally Posted by VT Calais View Post
Does anyone have any experience with
THIS or any other 1KW amp?
Look at this short post >
Can anyone help with an old ETI magazine article ??
This amp was my own built back in 1978 and quoted as a "monster stereo amp" in ETI-477 300 watt amp module. It had 24 output transistors 2N3055/MJ2955 in each channel and based on a highly modified set of ETI-413 modules. I basically redesigned the ETI413 100 watt amp circuit to deliver 600 watts into 2 ohms so that in bridge mode 2 modules gave me 600 watts into 4 ohms running on +/-45 volt Dc Rails. For stereo, I built 4 modules.
I also rebuilt the same basic amp a few years latter in a smaller case with half the amount of output transistors - 24x MJ15003 & MJ15004 devices ( 12 per channel ).
I'm now looking into maybe building another monster stereo amp ( or 2 mono blocks ) possibly with the new super bipolar transistors from Semelab, the MG9413K and MG6333K complementary devices. With the above amp - I had to get specially wound the 2 massive power transformers each delivering 64 volts AC @ 15 amps continuous ).
From these big amps I learn't quite a bit about amp construction and design. Unfortunately I failed to take not one photo. So many memories - so little evidence !
As for working on the Amp your interested in - NO I have not - But I've worked on Dc-Ac power Inverters which single "mono blocks" deliver up to 8,000 watts at 240 Volts Ac and have a string of power FETS extending into 50 or more in some units. In principle - these power Inverters are nothing more than a bloody big Audio Amp running at 50 cycles sine-wave ( and some square-wave ) having generally about <3% distortion - some with output transformers and others with directly coupled H-bridge arrangements.
The principles for building and testing such a beast, are not all that different from Audio. Some of these power Inverters can be coupled together for 3 phase or parallel operation extending up to 50Kw in size.
kimbalsummers@hotmail.com
Old 12th March 2017, 01:37 PM   #253
Originally Posted by vedmitraa View Post
Looks nicely made Amp mr. black can you share p.c.b.; component layout and schematics.
dear vedmitra,greetings for happy holy.u blocked me .due to this we are not aware each other.plz.unblock me so we can get thought each other.thanks
Who has built their own? markp Solid State 43 3rd August 2014 09:10 AM
Hi! And I built one too... The RB Chip Amps 4 13th March 2009 09:12 AM
i built these a while ago and roystr Full Range 11 10th November 2005 12:49 PM
Anyone built this amp? JojoD818 Solid State 26 19th August 2003 11:32 AM
Copyright 1999-2017 diyAudio
