#221 |
Please see, the smaller torrid primary is 40 amps x 240 volts = around 9.6 kw,and other one 60 amps. x 240 volts =14.40 kw. not 5 Kw. and I want to use them for 4 chanalles of amp on each traffo. And I will do that in near future, smaller one for 1.8 kw. class ab x 4 chanalles . and bigger one 2.5 kw x 4 channeles in class AB only.
Failure in Experiment is key to success .Only right combination is needed.
#222 |
I would definitely do a 100%-50%-0-50%-100% secondary winding and a class G output stage.
10 pair of MJ15024/25 will have a beta of 15 at 80A require about 5A of drive current, and about 250mA from the pre-driver (a triple output circuit). 80A peak would be 56.6A RMS, or about 3.2KW at 1Ω. The TO-66 250V/2A 30Mhz 40W SOA at 100V pre-driver I used is no longer available. I would probably use something like the 2SA1943/2SC5200, although rated at 40W SOA at 100V it will not be as robust due to its 150°C junction temperature rating vs the 200°C rating on the TO-66 part. If you could get the ON Semiconductor MJL/MJW 1302/3281 that would be even better with their 100W SOA at 100V they would be adequate. The top rail would be a duplicate of the bottom rail with a 6V level shift, so you would end up with roughly the same number of output devices you originally planned for, but much better reliability. This would essentially be the Crest 10004 output stage with your supply being much stiffer.
Candidates for the Darwin Award should not read this author. Last edited by djk; 4th January 2013 at 09:41 AM. |
#223 |
Thanks Mr. Djk for your real and valuable advice I have noted down,do you have this crest 10004 circuit,if you can post, I have 50 pairs of motorola 15024 and 25 with me I want to use them
thanks again
#224 |
#225 | |
#226 | |
can u share this amp pcb layouts. |
#227 |
well it is actually a modified version of super leach 700 watts with 16 pairs of 5200 , 1943 in output and one pair as driver,p.c.b. section only used upto predriver as yu can see in photos.Power really more than 1400 watts crispy h.f., melodious mids,and thumping bass, have now tested even with 6 nos. 18" speakers parallel for more than 4 hours.
#228 | |
#229 |
This Circuit has been published in this forum many times ,still once again
#230 | |
| Hi! And I built one too... | The RB | Chip Amps | 4 | 13th March 2009 09:12 AM |
| i built these a while ago and | roystr | Full Range | 11 | 10th November 2005 12:49 PM |
| Who has built their own? | markp | Solid State | 42 | 29th June 2004 09:42 PM |
| Anyone built this amp? | JojoD818 | Solid State | 26 | 19th August 2003 11:32 AM |
