Has any one built this 1KW amp? - Page 22 - diyAudio
Old 2nd January 2013, 10:35 PM   #211
kimberlator's Avatar
Default 1.5Kw Amp.
Originally Posted by vgeorgiev View Post
Yes, I've made it and with some minor modifications it will work, but not as per schematic, specially on the bias circuitry, you can modify it to get more power also, but that's pointless because there's already a very good amount of power.
Regards.
If you want a thing well done, then Do-It-Yourself
Old 2nd January 2013, 11:16 PM   #212
AJT is offline AJT  Philippines
AJT's Avatar
pulled some posts, guys let us stick to technical discussions please....
Do not despair, though they seem to be winning
now, they always fall in the end......Gandhi
Old 3rd January 2013, 05:00 AM   #213
djk is offline djk
djk's Avatar
I would suggest lowering the V by a factor of 0.707, this will be much safer, and require only about one-fourth the number of outputs (and half the number of drivers) due to SOA parameters of the devices used.
The reduction in power will only be 3dB.
I put together such an amplifier 20 years ago with only 10 pair of MJ15024/25 running 1Ω and it is still running fine today. It's probably about time to replace all the electrolytics though, I should contact the owner.
Candidates for the Darwin Award should not read this author.
Old 3rd January 2013, 07:41 AM   #214
vedmitraa's Avatar
Mr. djk can you share to all what you made 20 years ago
Failure in Experiment is key to success .Only right combination is needed.
Old 3rd January 2013, 08:35 AM   #215
AJT's Avatar
djk is suggesting that you back down your rails to about 90 volts if you value your output trannies....
Old 3rd January 2013, 04:32 PM   #216
wg_ski is offline wg_ski  United States
I would suggest lower than that to start off with. Maybe +/-45, +/-90 and +/-135V taps on the trafo. If you're doing a custom wind job anyway why not put the extra taps so you can convert to a multi-tier supply eventually? Something this big needs it to really be practical, and can operate class AB off the lower tier (or two) while the project is being developed.
I've run +/-127V in pure class AB, but the output stage was cascode (S-Leach type) with 5 parallel/2 series. The only part of it that ever burned up was the extension cord. It blows hot air like a hair dryer, and a 15 amp breaker won't stay in the 'on' position. Even 20 amp will nuisance-trip occasionally. All of my subsequent designs were class H - even the little 100 watter. I hope you have a dedicated 30A circuit just for testing.
To all the naysayers who say that "it won't put out anywhere near that much" need to take a close look at those toroids! Looks like about an 8kVA.
3kW into 2 ohms is a real possibility. 55 amps won't be a problem for that many output trannies or that big a toroid. Reliability is another issue - as it was with the original PL700. That's a design issue the can be addressed.... eventually. Workhorse's first iterations probably didn't work either.
Old 3rd January 2013, 11:37 PM   #217
AJT's Avatar
Default obsession for power
when i was younger i also dreamed of building the biggest and the mightiest amp......i am still dreaming.....
yes, you can build a 5kw amp out of that 8kva torroid...but then you will learn that there are amps out there more powerful that your 5kw amp, so where does that leave you?
classAB up to about 300watt is very practical imho....above that, classD, G, or H is available....
so then it becomes just a matter of adding more amps, more speakers to your system if more power is desired......
why put all your eggs in one basket? if the basket crashes, you lose all your eggs in one go.....
Old 4th January 2013, 12:22 AM   #218
JMFahey is offline JMFahey  Argentina
JMFahey's Avatar
True enough.
In the early 80's I designed and built a PA system for the Moscow Circus (the real, Soviet era one) .
They did NOT want a couple "big" amps.
On their spec, I built a ton of long *narrow* sound columns , each housing 8 6"x9" car type speakers mounted edge to edge , the columns were just 8" wide, because they were hung all around the huge stage and had to block vision the least possible, each block of 4 was powered by a dedicated rack of 6 100W amps , meaning 2 backups per rack.
Each rack had a patchbay so a dead one could be replaced in seconds, and all modules were plug-in , so they could be pulled for repair elsewhere, with the rack still working nonstop.
The reason behind that: Moscow Circus, when on tour, has *continuous" shows 1PM to 1 AM , every day of the week.
No time for "regular" maintenance, so the answer is a lot of redundance built-in.
If any 100W amp or column failed during the show, since they were 4 or 5 meters away , no "deaf" spots would be noticed, at most a somewhat lower SPL at some seats.
I think they approached problems with a "military" mindset.
And of course, a dead 1KW amp during a show would have been a disaster.
Old 4th January 2013, 07:36 AM   #219
vedmitraa's Avatar
Thank you Mr. Tony and Mr. Fahey.
For you Information let me tell you I have already practically made class AB amps up to real nondistorted power of 1400 watts per channel in to 2 ohm, see the photo attached, I have tested it in field for 6 hours with 8 speakers 15" direct and has passed the test.8/8 the load was 1 ohm, the meter in picture showing peak voltage on 2 ohm.with speakers in field it was 44 volts and 29 amperes.
Old 4th January 2013, 07:41 AM   #220
vedmitraa's Avatar
Default my 1400 watts per channel class Ab amp
Picture of my amp
Who has built their own? markp Solid State 43 3rd August 2014 10:10 AM
Hi! And I built one too... The RB Chip Amps 4 13th March 2009 10:12 AM
i built these a while ago and roystr Full Range 11 10th November 2005 01:49 PM
Anyone built this amp? JojoD818 Solid State 26 19th August 2003 12:32 PM
Copyright 1999-2017 diyAudio
