Has any one built this 1KW amp? - Page 21 - diyAudio
Old 30th December 2012, 06:12 PM   #201
wg_ski is offline wg_ski  United States
You better tape the **** out of those primaries before you go winding. And I'm not sure I'd trust that second one at all. Unless the insulation is in a lot better shape than it looks.
I'm not sure all this is going to fit in 4U. Or even 6.
Old 31st December 2012, 07:44 AM   #202
vedmitraa's Avatar
Thanks for the advice Mr. WG-SkI
First i will coat them with Vectol Insulating varnish twice,Than will tape with fibreglass Tape,will varnish again and than only will start winding
Failure in Experiment is key to success .Only right combination is needed.
Old 31st December 2012, 07:58 AM   #203
vedmitraa's Avatar
request to all the senior members Please check this circuit for faults, and if any modify it. Thanks and Happy New Year to All
Old 31st December 2012, 08:31 AM   #204
Wow, didn't know you could get a toroid THAT BIG!!! I'm in LOVE!!!
I would so have electronosechs with it!
Where in the world can you get/make a toroid like that?
You can call me Mad Professor, building crazy experiments in my Electronics Workshop
Old 31st December 2012, 08:38 AM   #205
djk is offline djk
djk's Avatar
Q9, 59 must be MJ15024
Q8, 60 must be MJ15025
You should add a pre-driver, making the output stage a triple. Use the MJE15034 and MJE15035.
I would add a 2.7K in series with the base of Q2 and move the 100pF to the base of same and change to 390pF, this forms a pole at about 125Khz.
Q4 and Q5 should run no more than about 10mA, so R11 and R12 should be more like 390Ω. With 4.3mA though each the voltage drop across 390Ω will be 1.68V, which will make the current in Q4 and Q5 about 10mA.
The amplifier might put out 5KW at 1Ω for a bit before it blows up. The SOA on the outputs is 100W at 100V. Run another supply tier and you could make it work properly in class G or H, or run the other tier from a tracking down-converter like a Sunfire or Bash amplifier.
I'm sure there will be more details, but this is all the time I have for now.
Candidates for the Darwin Award should not read this author.
Old 31st December 2012, 08:44 AM   #206
vedmitraa's Avatar
Greeting Mr. Workhorse,
This is just a theortical design,I also know that if I make a 20kw per channel and even if I use 15024-25 I will need minimum 2000 of them,in class AB, practically not possible,Just wanted that if seniors like you can check the circuit to make an amp of 4 to 5 kw per channel will be a great help for me
Old 31st December 2012, 08:48 AM   #207
vedmitraa's Avatar
Thanks Mr. Djk for your advice
I have noted down the sugetions and modifications you have made and that will be a great help for me. My aim is upto 5 kw. per channel in practical,and for that my newly bought traffo will be enough to power.
Old 31st December 2012, 08:59 AM   #208
Those amplifiers are SO BEAUTIFUL they bring a tear to my eye!
You are a genius when it comes to building amps! SO AWESOME!!!!
FAVORITE AMP THREAD!!!!
Old 31st December 2012, 09:24 AM   #209
vedmitraa's Avatar
Thanks Mr. EWorkshop1708
Are you there on face book, you can find me there by yhe name Vedmitra Sharma
Old 2nd January 2013, 07:10 PM   #210
Anyone checked http://sound.westhost.com/project117.htm
Last edited by wintermute; 2nd January 2013 at 07:19 PM. Reason: replaced link with direct non advertising link.
Who has built their own? markp Solid State 43 3rd August 2014 09:10 AM
Hi! And I built one too... The RB Chip Amps 4 13th March 2009 09:12 AM
i built these a while ago and roystr Full Range 11 10th November 2005 12:49 PM
Anyone built this amp? JojoD818 Solid State 26 19th August 2003 11:32 AM
Copyright 1999-2017 diyAudio
