Has any one built this 1KW amp? - Page 20 - diyAudio
Old 4th October 2012, 05:44 AM   #191
TonyTecson's Avatar
Originally Posted by kimberlator View Post
May Be You're About Right, But I Think It Depends On What Quality Pot You're Using, In My Personal Experience There's Nothing Better Than The Use Of Fixed Resistors, But That's Limits The Adjust, Sometimes Necessary, DC Offset, This Is Why I Always Use ALPS Sealed Precision Multiturn Potentiometers, This Way I Can Assure That You Don't Have Any Issues With Pot For Long Time, Or Make Proper Calculations To Get The Right Values With Fixed Resistors.....Just My Point Of View, Best Wishes To Anyone
the cost of potentially losing all of the output trannies alone is reason enough to think of ways to get rid of the pot altogether, matching input LTP's is one of them.....
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 4th October 2012, 02:08 PM   #192
wg_ski is offline wg_ski  United States
You won't "lose all of those output trannies" if you lose the offset null pot. But it will put DC - a lot of DC - to the speaker
The real reason to get rid of the pot is noise. Pots are noisier than any resistor and an input stage is the worst place to put noise.
Old 4th October 2012, 03:24 PM   #193
kimberlator's Avatar
Well, I Don't Remember Any Issue About Open Pot Or Noisy Signal Due To A LTP Pot Anyway..At Least Not In My Amps Designed And Built By Myself, Not A Single Issue On That Particular Matter, For What I've Reading Here Now I Think Is Pure Good Luck....
If you want a thing well done, then Do-It-Yourself
Old 4th October 2012, 07:45 PM   #194
vedmitraa's Avatar
Okay can't we do this,
First make and Test Amp with pot ,set it after half an hour of full load testing, check again then measure and change the values with fixed resistances.i always try to match hfe of transistors.
Failure in Experiment is key to success .Only right combination is needed.
Old 10th October 2012, 09:29 AM   #195
3kW into 2r0 requires an output of 109.5Vpk.
Do you really think you amplifier can manage to get that output voltage level when delivering 54.77Apk?
You are in dreamland.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 14th October 2012, 04:36 AM   #196
vedmitraa's Avatar
Is it only the voltage which determines the output, is there no part of current in wattage,If it is so than v x I=w is not correct, what I read up til now is wrong?
Old 14th October 2012, 04:38 AM   #197
TonyTecson's Avatar
Ohm's law required only 2 viarables to get the 3rd, P = E^2/R this is the power equation....in current terms, P = I^2 x R
Old 14th October 2012, 05:26 AM   #198
Workhorse's Avatar
Fantasy world is so lovely
Old 14th October 2012, 07:46 AM   #199
TonyTecson's Avatar
dream on guys...it's free and build those high power amps....
Old 30th December 2012, 03:54 PM   #200
vedmitraa's Avatar
Default my new torrid verses earlier one
Now my old torrid has become smaller,I got a big brother for it,That was 40 amps 230 volt and this one 60 amps 230 volt, only 35 k.g. weight, Secondary to be wound on both
Who has built their own? markp Solid State 43 3rd August 2014 09:10 AM
Hi! And I built one too... The RB Chip Amps 4 13th March 2009 09:12 AM
i built these a while ago and roystr Full Range 11 10th November 2005 12:49 PM
Anyone built this amp? JojoD818 Solid State 26 19th August 2003 11:32 AM
Copyright 1999-2017 diyAudio
