Has any one built this 1KW amp? - Page 18 - diyAudio
Old 13th September 2012, 01:55 AM   #171
kimberlator's Avatar
Certainly There's Very Very Few Namebranded Amps That Do What They Claim, I Don't Know, Lets Say POWERSOFT? CAMCO? LabGruppen? But Even For Those Badass Amps There's No Substantial Rules & Regulations About Power Ratings In Their Wide Range Of Technical Tests, So They Can Easily Claim Overrated Parameters On Their Products, And Hell Lets Speak The Truth Between Us, How Many People You Know That Have Any Knowledge About Amp Specs? They Need Just A Thing To Put Sound On Their Speaker System And That's It !!! Very Few People Cares Even About Speaker Impedance.
Just My Point Of View.....
Cheers To Anyone.....
If you want a thing well done, then Do-It-Yourself
Last edited by kimberlator; 13th September 2012 at 01:58 AM. Reason: Correct Information !!!
Old 13th September 2012, 02:05 AM   #172
AJT is offline AJT  Philippines
AJT's Avatar
as long as we are aware that most power claims are just that, claims, then i guess we are on the ground....the dreamin' goes on.....
it is either FTC or it is not.....
the best advertisement for a good audio design is the number of diy'ers wanting to build it after all the years....never the say so of so called gurus....
Old 13th September 2012, 06:44 PM   #173
Default ?
Yes, We Are Aware So All People Are, But Not Everyone Know For Sure If "PYLE" Amplifier Will Deliver 1000Watts Per Channel @4R As The Amp States In Its Front Plate, Right?
"PYLE" Amplifier Will Deliver 1000Watts Per Channel @4R..Hummmmm......FTC Or EIA? Or Both? And Believe It Or Not This Same Issue Applies In A Very Wide Variety Of "NAMEBRANDED" P.A. Amps, Because As The Article Reads "There's No Such Regulations For Professional Audio Equipment" Nice Dont You Think????
Last edited by kimberlator; 13th September 2012 at 06:51 PM. Reason: Correct Information !!!
Old 17th September 2012, 02:08 AM   #174
DIYGEEK is offline DIYGEEK  United States
Default I'm in...!!!
I have two large transformers from QSC amplifiers USA1310 and MX1500
I desire to build a large 500watt 8 ohm amp capable of 4 ohm sub work.
I like Workhorse design seems very roubust... lets continue this was getting intresting.
A posting of Rods revised circuit would be great too.
My transformers hit 95 volts after regulation, would love a great circuit for them.
Pat
Old 17th September 2012, 04:46 PM   #175
Aniket is offline Aniket  India
Aniket's Avatar
@ Sir Vedmitraa
Maybe you have done a mistake, as in the pic you have connected 0.22R resistor to the base of the transistor which goes to the output, and 4.7R resistor to the emitter of the transistor on both sides, Kindly check before powering up.
Aniket
Old 19th September 2012, 08:54 AM   #176
vedmitraa's Avatar
Thanks Aniket for pointing out the fault.that photo is quite old yeah there was this mistake but I rectified that mistake next day.Here is the photo of working amp with 1 ohm load and digital meter connected at output with test tone of 1khz.Meter is showing output voltage.
Failure in Experiment is key to success .Only right combination is needed.
Old 19th September 2012, 09:12 AM   #177
east electronics's Avatar
I am not familiar with any instrument at least like the ones shown in the picture that are able to measure correctly anything above 400HZ but may be i am wrong .....
SERVICE ΕΝΙΣΧΥΤΩΝ ΚΑΙ ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr
Old 19th September 2012, 09:23 AM   #178
AndrewT is online now AndrewT  Scotland
I have used my cheap DMM @ upto and including 50kHz.
I use the comparison method when ever I need good accuracy and/or repeatability.
If I set up an input attenuator that exactly cancels the gain of the amplifier under test, then I can compare the input voltage before the attenuator with the output voltage after the amplifier.
I am comparing DMM Vac readings that are the SAME voltage and the SAME frequency.
If the DMM tells me the voltages are the same, then I believe it. Even when I know that the DMM is decades outside it specified operating frequency range. eg, the input could be set to read 2Vac at 200Hz and at 900Hz, but might read 1.4Vac at 10kHz and 525mVac at 50kHz.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 19th September 2012, 07:49 PM   #179
vedmitraa's Avatar
Well I am not that much in theories but when measured with this meter it gave me 66 volts on 100hz ;61.4 volts on 1khz and 52 volts on 20 khz;on 1 ohm load at output signal voltage 1volt with my signal generator on sine wave and rail voltage 90-0-90 on load.
Old 21st September 2012, 09:59 PM   #180
vedmitraa's Avatar
Default works I have been doinng
Thanks to all seniors in diyaudio because of them i could do this work ,some of my works photos,please see my page at facebook for more photos.
Vedmitra Sharma
Who has built their own? markp Solid State 43 3rd August 2014 10:10 AM
Hi! And I built one too... The RB Chip Amps 4 13th March 2009 10:12 AM
i built these a while ago and roystr Full Range 11 10th November 2005 01:49 PM
Anyone built this amp? JojoD818 Solid State 26 19th August 2003 12:32 PM
Copyright 1999-2017 diyAudio
