Has any one built this 1KW amp? - Page 11 - diyAudio
Old 12th August 2012, 11:56 AM   #101
Workhorse's Avatar
Originally Posted by vedmitraa View Post
Paa ji Sat Shri Akal ,
Is the circuit on page1 post6 of this thread complete. Kya yeh naachees can give this circuit a try with your guidance.Planning to pu 16 pairs 15024 - 25 that is toatl 32 in output. will a 2.5 kva transformer will be enough for this amp.Is nachhese ki choti si work shop ka photo saath hai.regards
Uncle Andy is already giving it a try, you too can try it without any hassles.
Old 12th August 2012, 04:55 PM   #102
kimberlator's Avatar
I'll give it a try and post results ASAP, i'll use complementary pairs of MJL4281A & MJL4302A from ON semiconductors along with MJE15034 & MJE15035, i'll keep you updated about progress of this new task, See ya....
Old 12th August 2012, 05:06 PM   #103
Sir Kimberlator, kindly can you please post schematic how to connect the output complementary.
Old 12th August 2012, 09:01 PM   #104
vedmitraa's Avatar
Sat Shree Akal again Paaji,
I have no more connection with Andrew Lebon. Wo aapki meharbanion es bahut unchi chees ban gaya hai success has got his mind.This is what I have done recently.Meter is showing Peak output voltage with 2 ohm load .Rail voltage 85-0-85.Continuos output voltage into 1 ohm load with .8 voltage music signal reached upto 43 volt. My aim is to achieve 60 voltage undistorted into .5 ohm load
Old 13th August 2012, 07:11 AM   #105
Workhorse's Avatar
What do you mean to say?
Zara khul ke bata, mamla kya hai?
Old 13th August 2012, 09:16 AM   #106
AJT is offline AJT  Philippines
AJT's Avatar
is that a leach lo-tim amp you have there?
Do not despair, though they seem to be winning
now, they always fall in the end......Gandhi
Old 13th August 2012, 10:37 AM   #107
djk is offline djk
djk's Avatar
Other than the lack of feedback from the driver stage, and the lack of diodes in the bias circuit, it sure looks like a Leach.
Candidates for the Darwin Award should not read this author.
Old 13th August 2012, 01:49 PM   #108
east electronics's Avatar
multiplying the number of outputs will not make a high power amplifier
amplifier of this range of power will need proper protection
---one may calculate how much current will be drawn from this circuit per rail and then realize that a ""wire "" of 1.5mm cannot and will not deliver this amount of current
--Then again there is so many transistors placed in such a proximity in a relatively thin pcb that will actually warm each other up .... the result will be that even if a vent is used it will be not possible to cool down the amp ....fins are too small ...
---It should be plenty more ....
SERVICE ΕΝΙΣΧΥΤΩΝ ΚΑΙ ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr
Old 13th August 2012, 01:56 PM   #109
Yes, It is sure a leach amp alright..look at the background schematic. originally its a 700w 16TR design but he doubles it.
Old 13th August 2012, 02:53 PM   #110
But D.Self shows us that doubling the output stage lowers the distortion, even into the same loading.
Look at his Blameless and compare to the Load Invariant.
But, using 1943/5200 at high voltage is a complete waste of semiconductor devices.
No matter how many one uses, there are far better devices available that can work well at the higher voltages. These higher SOAR devices can reduce the required numbers of output BJTs by a factor of at least 2 and often better than a factor of 3.
regards Andrew T.
Sent from my desktop computer using a keyboard
Who has built their own? markp Solid State 43 3rd August 2014 10:10 AM
Hi! And I built one too... The RB Chip Amps 4 13th March 2009 10:12 AM
i built these a while ago and roystr Full Range 11 10th November 2005 01:49 PM
Anyone built this amp? JojoD818 Solid State 26 19th August 2003 12:32 PM
Copyright 1999-2017 diyAudio
