Has any one built this 1KW amp?
Old 17th January 2013, 09:54 PM   #231
TonyTecson is offline TonyTecson  Philippines
TonyTecson's Avatar
^agreed, the Leach Superamp has a different topology wrt to the output stage, with today's available output trannies like the MJ21193/Mj21194, rails of up to +-150 volts is possible....
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 18th January 2013, 07:11 AM   #232
djk is offline djk
djk's Avatar
With the MJ21195/96 the standard Leach is useable to about 100V. Above there I would go to a super-super Leach, cascoded with a level shift and a tiered supply and ORing diodes (class G). See the Crest 8001 for the general idea.
http://www.crestaudio.com/media/sche...matic_set1.pdf
Candidates for the Darwin Award should not read this author.
Old 20th January 2013, 02:14 PM   #233
vedmitraa is offline vedmitraa  India
vedmitraa's Avatar
Thanks Mr. DJK for posting crest circuit, please post Super leach Cascode Circuit also
Failure in Experiment is key to success .Only right combination is needed.
Old 20th January 2013, 11:42 PM   #234
djk is offline djk
djk's Avatar
I'm suggesting you adapt the Crest schematic, it's essentially the Leach.
The basic Leach has a class AB output stage. The Super Leach has a series connected output stage to reduce the high voltage SOA demands, a bit like a cascode but the drive voltage tracks at half the required output voltage.
The Crest is like the class AB Leach with the series connected outputs of the Super Leach. When it runs close to the low volt rail the level shift zener then cascodes the series connected outputs rather than trying to do a half voltage thing. This is class G.
The Super Leach does a series connected Vas stage that also tracks the half voltage like the outputs. I would not do this, just do it like the Crest, or do a fixed cascode with an LED reference is you want to.
I assume you have the Super Leach schematics?
(they were just for reference only to compare the topology with the Crest)
Old 21st January 2013, 05:51 AM   #235
vedmitraa's Avatar
Thanks Mr. DJK,
While searching I found all the files of Super leach in my computer including P.C.B. when Leach is giving me so good results I think super leach will do wonders with voltage divided, I will give it a try and I think this will be a hit like Leach, thanks for the Crest file also.
warm regards
Old 21st January 2013, 03:19 PM   #236
vedmitraa's Avatar
Default Relays for soft start of my 60 amp. 240 v. primary torrid
Thanks, for the advice,
mean while I have got some relays for the soft start circuit to be used with my 60 Amps. 240 Volts primary torrid and 40 Amps 240 volt primary torrid photos of which I have posted earlier. These relays coil 24 volts D.C. 4pair 30 Amps. silver and Silver carbon contacts each, please post a suitable soft start circuit if any body have
Old 7th March 2013, 01:07 PM   #237
sameer x1 is offline sameer x1  India
Default DISTORTION
Hello Workhorse Sir
i assembled your drive its working but at low volume sound
is distorted i tested drive on 1 pair 2sc5200 at 8 ohms load on 70 volts dc +/-
will distortion go if i add more pairs
warm regards
sameerx1
but what remains silly is the distortion at low volume even Kimberlator experienced this distortion
Old 7th March 2013, 01:26 PM   #238
Workhorse is offline Workhorse
Workhorse's Avatar
Originally Posted by sameer x1 View Post
Hello Workhorse Sir
warm regards
sameerx1
To enhance the low level signal clarity, put one more diode connected transistor in series with other two already in the schematic and set the trimmer accordingly to get 20mA idle current in output devices.
Old 10th March 2013, 04:53 AM   #239
andrewlebon is offline andrewlebon  India
andrewlebon's Avatar
Default Hello
Hi Workhorse
greetings today is a very special day for you HAVE FUN
warm regards
andrew
"It's Better to try and fail than to never know and always wonder"
Old 10th March 2013, 08:58 AM   #240
vedmitraa's Avatar
Default ULTRA-CLEAN
Friends here I present A design Named by me "ULTRA- CLEAN". this is around 1KW at 2 ohm's load with distortion down to "0.001%".for real hi-fi lovers and with a slight change around 2 kW. on 1ohm load at 0.002% distortion and, on 2 ohm more than 48 volts at out with 0.002% distortion and around 1116 watts
Has any one built this 1KW amp?Hide this!Advertise here!
Who has built their own? markp Solid State 43 3rd August 2014 09:10 AM
Hi! And I built one too... The RB Chip Amps 4 13th March 2009 09:12 AM
i built these a while ago and roystr Full Range 11 10th November 2005 12:49 PM
Anyone built this amp? JojoD818 Solid State 26 19th August 2003 11:32 AM
Copyright ©1999-2017 diyAudio
