Has any one built this 1KW amp?
Old 21st August 2012, 04:50 AM   #131
kimberlator is offline kimberlator  United States
kimberlator's Avatar
For Your Consideration...
MG633x/MG941x
  • Designed specifically for linear audio amplifier applications
  • High-speed fir gufg bandwidth amplifiers
  • High voltage rating 230V & 260V
  • Plastic TO-3P and TO-264 and metal TO-3 Packages
  • Wide Safe Operating Area for high power output
  • Complementary NPN and PNP parts
Applications:
  • Professional audio amplifiers
  • Home Cinema
  • Hifi
  • Instrument amplifiers
  • Active speakers and subwoofers
  • Car Audio
Advantages:
  • Wide Safe Operating area
  • Extended High frequency performance
  • Excellent thermal performance - smaller package for a given power
  • Industry standard TO-3P package achieves higher power than larger TO-264 from competitors
  • Unsurpassed linearity of hFE
  • Low Saturation voltage
  • Enhanced sound quality
  • No Secondary breakdown exhibited unitl beyond 100V
MG6332/3 & MG9412/13 Advantages:
  • Unprecedented 30A ouput current rating 100V, 4A SOA capability
  • High power - 400W sing package capability
Click the image to open in full size. Click the image to open in full size.
Product Line Up
Part Number Polarity Vceo(V) Ic (A) Pc(W) Ft(MHz) hFE(min)@10A Package
MG6330 NPN 230 15 200 60 50 TO-3P
MG9410 PNP 230 15 200 35 50 TO-3P
MG6330-R NPN 260 15 200 60 50 TO-3P
MG9410-R PNP 260 15 200 35 50 TO-3P
MG6331 NPN 230 18 300 60 50 TO-3P
MG9411 PNP 230 18 300 35 50 TO-3P
MG6331-R NPN 260 18 300 60 50 TO-3P
MG9411-R PNP 260 18 300 35 50 TO-3P
MG6334K NPN 230 15 200 60 50 TO-3
MG9414K PNP 230 15 200 35 50 TO-3
MG6335K NPN 260 15 200 60 50 TO-3
MG9415K PNP 260 15 200 35 50 TO-3
MG6332 NPN 230 30 400 60 50 TO-264
MG9412 PNP 230 30 400 35 50 TO-264
MG6333 NPN 260 30 400 60 50 TO-264
MG9413 PNP 260 30 400 35 50 TO-264
MG6332K NPN 230 30 400 60 50 TO-3
MG9412K PNP 230 30 400 35 50 TO-3
MG6333K NPN 260 30 400 60 50 TO-3
MG9413K PNP 260 30 400 35 50 TO-3
http://products.semelab-tt.com/magnatec/bipolar.shtml
TTElectronics/SEMELAB.
Specially For Hi-Power Audio With Excellent SOA....
What's Your Opinion????
Enjoy And Comment....
Old 21st August 2012, 04:58 AM   #132
TonyTecson is offline TonyTecson  Philippines
TonyTecson's Avatar
hi, are you connected with SEMELAB? and where can these devices be availed of and at what price breaks? thanks...
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 21st August 2012, 05:29 AM   #133
Exclamation MOSFET's For Audio Applications
Well, That's Something To Find Out, But This Components Show Very Good Specifications Don't You Think?
And Here Are MOSFET's For Audio Applications:
Power Amplification - ALFET Lateral MOSFETs
Click the image to open in full size. Applications:
• Professional Audio Amplifiers
• Home Cinema
• Active Speakers and subwoofers
• High power car audio
Advantages:
Specifically designed for audio power amplifier output stage applications, ALFET Mosfets are an exclusive new range of devices with outstanding performance and a minimal footprint. They offer superb sonic characteristics and with the features listed below its not hard to see how we can help you to reduce size, cut costs and add real quality and functionality to your design.
• A wide safe operating area (SOA) and absence of secondary breakdown
• Reliable and robust performance when compared to bipolar solutions
• Simplified protection saving cost & reducing complexity
• Improvement of amplifier performance with awkward loads
• Oscillation-free operation on double-die devices
ALFET Mosfets also have a negative temperature coefficient and completely thermally stable bias point without the need for emitter resistors, as used in bipolar amplifiers.
Advanced technical features include:
• Simplified drive circuitry requirements through high
impedance gate
• Inherent output anti-parallel diodes
• Excellent thermal characteristics
• Single live heatsink capability (source connected case)
• Very high bandwidth and slew rate
• No high frequency cross conduction
• Easy paralleling (devices available in selected categories to enhance paralleling performance)
• Soft clipping performance
Application Note
Lateral MOSFET Design recommendations for Audio Amplifiers
TO264
TO247
TO3
TO247-5L
Datasheets & Shortform
Part No. Polarity VDSS(V) Current ID(A) PD(W) Package Comments ALF08N16V N-channel 160 8 125 TO-247 ALF08P16V P-channel 160 8 125 TO-247 ALF08N16K N-channel 160 8 125 TO-3 ALF08P16K P-channel 160 8 125 TO-3 ALF16N16W N-channel 160 16 250 TO-264 ALF16P16W P-channel 160 16 250 TO-264 ALF16N16K N-channel 160 16 250 TO-3 ALF16P16K P-channel 160 16 250 TO-3 ALF08NP16V5 N&P 160 +/-8 TBD TO-247-5L In Development ALF08N20V N-channel 200 8 125 TO-247 ALF08P20V P-channel 200 8 125 TO-247 ALF08N20K N-channel 200 8 125 TO-3 ALF08P20K P-channel 200 8 125 TO-3 ALF16N20W N-channel 200 16 250 TO-264 ALF16P20W P-channel 200 16 250 TO-264 ALF16N20K N-channel 200 16 250 TO-3 ALF16P20K P-channel 200 16 250 TO-3 ALF08NP20V5 N&P 200 +/-8 TBD TO-247-5L In Development
Just Check And Comment, I've Found This Very Attractive To Build A Hi-Power Amp With Less Transistor Count On Power Stage Mantaining High Power Output.
Old 21st August 2012, 05:35 AM   #134
Talking Hello...
Hello Tony,
I've Entered All Information For Those Who Encounter Interest In Such Components,
I've Just Found This Site By Accident, I'll Try To Make Contact, As They Offer Email Address And Other Contact Information.
Just Post The Information Because Sounds Very Good To Start A DIY Project With Such Hi-Power Components....
Cheers...
Old 21st August 2012, 05:37 AM   #135
Exclamation Here We Go Again...
Contact
Semelab Ltd
Coventry Road
Lutterworth
Leicestershire
LE17 4JB
Tel: +44(0)1455 552505
Fax: +44(0)1455 552612
Email: sales@semelab-tt.com
A subsidiary of TT electronics plc
Brochures
Links
Everything To Make Contact Bud....
Best Regards...
Old 21st August 2012, 07:46 PM   #136
vedmitraa is offline vedmitraa  India
vedmitraa's Avatar
Here I go Again With all you learned people's advice in same leach circuit with some changes and 15024-25 I have reached my goal of 70 volts and much more pressure. Here is snap of a new circuit I designed on multisim 11 . See the specifications with 24 pairs 15024-25 2 pair drivers and 120-0-120 rails
File Type: jpg Copy of ALPHATRONICS AMP 20 KW 24-25 duble.jpg (190.6 KB, 175 views)
Old 22nd August 2012, 12:10 AM   #137
TonyTecson's Avatar
goodluck on your build....
Old 23rd August 2012, 08:19 AM   #138
vedmitraa's Avatar
I already have this primary wound traffo and collection of trannies for my project.I only try the things when I have resources .Primary is with 8 s.w.g. A coat of vectol varnish . Insulatig cotton tape and then secondry to my needs. an traffo is ready. for supply.you can imagine power by size.
Old 23rd August 2012, 09:09 AM   #139
AudioSan is online now AudioSan  Norway
what the he.... 11-12" trafo? whats your plan? start up a power plant?
Old 23rd August 2012, 09:16 AM   #140
TonyTecson's Avatar
Originally Posted by vedmitraa View Post
I already have this primary wound traffo and collection of trannies for my project.I only try the things when I have resources .Primary is with 8 s.w.g. A coat of vectol varnish . Insulating cotton tape and then secondry to my needs. an traffo is ready. for supply.you can imagine power by size.
awesome, you are going to need a magnetic contractor to turn that thing on.....
Has any one built this 1KW amp?Hide this!Advertise here!
Who has built their own? markp Solid State 43 3rd August 2014 10:10 AM
Hi! And I built one too... The RB Chip Amps 4 13th March 2009 10:12 AM
i built these a while ago and roystr Full Range 11 10th November 2005 01:49 PM
Anyone built this amp? JojoD818 Solid State 26 19th August 2003 12:32 PM
