Has any one built this 1KW amp? Has any one built this 1KW amp? - Page 13 - diyAudio
Old 17th August 2012, 06:43 PM   #121
75Vpk is roughly equivalent to 350W into 8r0.
Look at amplifiers that state 300W to 400W. You will find many on this Forum.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 17th August 2012, 11:46 PM   #122
TonyTecson is offline TonyTecson  Philippines
TonyTecson's Avatar
Originally Posted by vedmitraa View Post
Any senior member If you have be please kind enough to post a working driver circuit to give me around 75 volts at output in class ab with bjt.As I told earlier power supply and mj 15024-25 no problem for me.
regerds
75 volts into 8ohms at output implies rails of +-112volts at full power, unloaded rails will be higher, about +-140volts....
your Output devices needs to be able to withstand about 300 volts....
imho, you are better off doing classH instead...
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 19th August 2012, 01:59 PM   #123
vedmitraa is offline vedmitraa  India
vedmitraa's Avatar
I think with 15024-25 I can go up to 120 volt rail.24 pairs will give me .5 ohm handling. supply I will make 87-0-87 x2-30 amp primary that is 11 s.w.g in primary and 12 s.w.g in secondary for a toroidal core of 40 amps. I am up to that. Meanwhile Transformer for one channel in process .Attached are photos of trafo, my stock of cores,and another project started 2 years ago now time to start again.
Old 19th August 2012, 02:53 PM   #124
1000W into 2r0 requires 63Vpk.
This could be got from loaded supply rails of ~+-70Vdc.
These will probably rise to ~+-80Vdc when the amplifier is ticking over.
Your 12pair output stage using MJ15024/5 should be OK with that.
But why aim for 2ohms loading.
Why don't you build two amplifiers for 4ohms loading?
Your audience are more likely to hear your signals because two amplifiers driving two sets of speakers are more likely to keep on playing.
regards Andrew T.
Old 19th August 2012, 05:31 PM   #125
djk is offline djk
djk's Avatar
"I think with 15024-25 I can go up to 120 volt rail."
Not and have any SOA left.
http://www.onsemi.com/pub_link/Collateral/MJ15022-D.PDF
50V=5A (250W)
80V=2A (160W)
100V=1A (100W)
150V=0.3A (30W)
I suggest using MJ21195/96 above 80V rails.
Candidates for the Darwin Award should not read this author.
Old 19th August 2012, 06:12 PM   #126
djk is offline djk
djk's Avatar
As a side note:
I have used a Leach output stage with 10 pair of MJ15024/25 with another pair of same as drivers to run a 1Ω load with 80V rails. Still running fine after 20+ years. Another one running 63V into 2Ω with three pair of MJ15011/12 blew up after about 25 years (the owner liked to drive it hard into clipping from time-to-time).
Old 20th August 2012, 09:11 AM   #127
DJK,
i am surprised the 3pair running into 2ohms lasted as long.
Just goes to show how gentle "loud" music is to the amplifier.
3pr @ ~250W gives a maximum output of ~300W. That 300W would be delivered into 4r0 from a +-60Vdc PSU, not 2r0.
This should be rated as a 4ohm capable amplifier.
10pr of 250W devices gives a capability of ~1000W
regards Andrew T.
Old 20th August 2012, 06:41 PM   #128
vedmitraa's Avatar
Well Mr. DJK and Mr. Andrew T.
Thanks for showing interest in my project.I am talking about 24 pairs that is 48 transistors in one channel.I have 50 pairs 15024-15025 Motorola not On with me. earlier I have used 10 pairs in one channel in dirty harry by Fotios and it is running perfectly up to 1 ohm load since 3 years.I am already using 90-0-90 in same . so I think to achieve my goal of 70 volt output in .5 ohm load with a driver circuit with rail of 120-0-120 will solve it. It is not my audience for whom I want to make this Amp. For my programes I always use Multi frequency divided system up to 6 divisions that is Subwoofer, Bass,Upper bass,lower mid,Mid.Upper mid and H.f.I do not use passive crossover not even active crossover. I use six equalizers+ 3 more for monitoring.and use up to14 stereo Amps for most of my shows. All my own made boxes and Amplifiers. I am sending Photo of one of my show.
regards
Old 20th August 2012, 11:43 PM   #129
TonyTecson's Avatar
regards
are you sure? 70 volt output in .5 ohm load is 11250 watts......you will need a traffo the size of a pole distribution transformer...
Old 21st August 2012, 01:18 AM   #130
Ricdelros is offline Ricdelros  Philippines
Looks like we have the same shop here..I only lack Instruments..
Has any one built this 1KW amp?Hide this!Advertise here!
Who has built their own? markp Solid State 43 3rd August 2014 09:10 AM
Hi! And I built one too... The RB Chip Amps 4 13th March 2009 09:12 AM
i built these a while ago and roystr Full Range 11 10th November 2005 12:49 PM
Anyone built this amp? JojoD818 Solid State 26 19th August 2003 11:32 AM
Copyright ©1999-2017 diyAudio
