Has any one built this 1KW amp?
Old 3rd August 2012, 10:48 AM   #91
Jansaen is offline Jansaen  Thailand
Originally Posted by andrewlebon View Post
Hi Kimberlator
greetings please can you tell which schematic you made this is the one with 560 ohms and 38k in input section this pcb is for trial run only
so only one pair mje15032 33
warm regards
andrew
Hello.,andrewlebon
May i have to see the PCB of your design.
I would like to make this Amp.
Thanks.
Jansaen
Old 3rd August 2012, 04:43 PM   #92
kimberlator is offline kimberlator  United States
kimberlator's Avatar
Thumbs up "Old Bullet-Proof Design"
Originally Posted by Workhorse View Post
Thats very old design of mine.
As Paul already said, the diode connected trannies must be attached to heatsink in order to get proper heat tracking. To enhance the low level signal clarity, put one more diode connected transistor in series with other two already in the schematic and set the trimmer accordingly to get 20mA idle current in output devices.
Thank you Kanwar, sonics are very good indeed, one of the main interesting things about your design is the fact that looks like is a "Bullet-Proof" design, i've managed down to 1 - 1.5ohm without issues, other than the lots of heat to get rid off of it, but since main outputs are mounted on a well-suited heatsink it's no big deal.Thank you and hope to see some of your newer designs as well with 3 main objectives:Class AB, Compact and of course, Powerful.
Old 6th August 2012, 03:39 PM   #93
andrewlebon is offline andrewlebon  India
andrewlebon's Avatar
Default GAIN STAGE
WORKING ON IT
"It's Better to try and fail than to never know and always wonder"
Old 6th August 2012, 07:33 PM   #94
Exclamation Wiring Vol At Pre-Amp Input
Your Volume Pot Isn't Properly Connected At Pre-Amp Input.
Here Are The Correct & Incorrect Modes,
Check Out Both Andrew.
Best Regards.
Last edited by kimberlator; 6th August 2012 at 07:36 PM. Reason: Correct Information!
Old 6th August 2012, 11:50 PM   #95
ynopac is offline ynopac  Philippines
sir workhorse where is the circuit diagram ..pag paguni kan sa met...
Old 7th August 2012, 06:04 AM   #96
Workhorse is offline Workhorse
Workhorse's Avatar
Scroll back some pages and you will see, how silly for some members who don't do their homework and want spoon feeding.
Old 7th August 2012, 05:30 PM   #97
Default Funny But True !!!
"Spoon Feeding" lol....
Old 11th August 2012, 07:43 PM   #98
vedmitraa is offline vedmitraa  India
vedmitraa's Avatar
Paa ji Sat Shri Akal ,
Is the circuit on page1 post6 of this thread complete. Kya yeh naachees can give this circuit a try with your guidance.Planning to pu 16 pairs 15024 - 25 that is toatl 32 in output. will a 2.5 kva transformer will be enough for this amp.Is nachhese ki choti si work shop ka photo saath hai.regards
Old 11th August 2012, 08:10 PM   #99
pankaj kashyap is offline pankaj kashyap  India
sir i want to build this amp,plz send shortcircuit protection schematic.
Old 12th August 2012, 10:55 AM   #100
Workhorse's Avatar
This circuit is very old, better to build the 1.5KW class-H instead which has complete set of protections.
Has any one built this 1KW amp?Hide this!Advertise here!
Who has built their own? markp Solid State 43 3rd August 2014 09:10 AM
Hi! And I built one too... The RB Chip Amps 4 13th March 2009 09:12 AM
i built these a while ago and roystr Full Range 11 10th November 2005 12:49 PM
Anyone built this amp? JojoD818 Solid State 26 19th August 2003 11:32 AM
Copyright ©1999-2017 diyAudio
