Hello
greetings can anyone tell the value of the resistor R21 or R121 located
near the 330pf caps there are 2 resistances in parallel 27K and the resistance with the colour code starting from the right RED ORANGE GREY BROWN brown indicates 1% value resistor so what would be the value of the resistor
warm regards
andrew
warm regards
andrew
One of the finest I know: Resistor color code calculator - 3, 4 and 5 band resistors
The big clue was that all the other resistors were 5% gold banded.
For some reason the added resistor is a 2% and yet it looks like it is in parallel to a 5% of similar value (is it 27k?)
Some manufactures will mark a 1% or 2% resistor with a brown (1%) or red (2%) band following a gold band in the fourth position. This is so you you won't read it backwards as the tolerance is always the fourth band.
However many metal film resistors have unique color codes and use spacing to break up the bands.
The safest way is to use an ohm meter and check before you solder it in. This is what I do with 1% metal films because I can never accuratly read the bands. Red often looks like brown against the light blue resistor casing the metal films typically use..
- resistor colour code
