HIGH Power Sub amplifier? - diyAudio
Old 4th January 2004, 12:20 AM   #1
Killjoy99's Avatar
Default HIGH Power Sub amplifier?
I know alot of people have been asking about Sub Amplifiers but I can't seem to find what I'm looking for. I'm planning on using a PPI Pro Flat piston 10 for my HT and music listening.
The sub is rated at 300 RMS and it's a single 4ohm voicecoil. Anyone know of a 300-400 watt Sub amp that can run continuously into a 4ohm load. I have looked at the 300w Subwoofer amplifier on ESP and was trying to find a few more alternatives.
http://sound.westhost.com/project68.htm
I also have looked into the Leach amps but have been unable to find a version that will output 300-400w RMS into 4ohms.
http://users.ece.gatech.edu/~mleach/lowtim/
Old 4th January 2004, 11:55 AM   #2
Workhorse's Avatar
Arrow Reply
CLASS_D OR CLASS_AB AMP PLEASE CONFIRM???
Old 4th January 2004, 05:46 PM   #3
Killjoy99's Avatar
Default CLASS_D OR CLASS_AB AMP PLEASE CONFIRM???
I do not have much experience with Class D DIY amps. I would assume a Class AB would be more fitting for this application. I am really just trying to find some other possiblilities, so really any projects complete with PCB layouts, component lists and a schematics would help. I would be interested in reading up on Class D construction if you have any information on some possible amps. Thanks
Old 4th January 2004, 07:17 PM   #4
ukram is offline ukram  Finland
ClassD is good for subs, because it has good efficiecy -> lots of power can be generated without cooling problems. Also distortion is lower for low frequencies.
I'm currently designing a classd amp.
Simulation picture (just the integrator and simple oscillator and comparator):
http://hepso.dna.fi/misc/classd/clas...simulation.jpg
And the LTSpice simulation file:
http://hepso.dna.fi/misc/classd/clas...simulation.asc
Old 4th January 2004, 10:57 PM   #5
The one and only
Nelson Pass's Avatar
Default Re: HIGH Power Sub amplifier?
Looking at the Leach amp, it probably would do the job as
specified, and if you are insecure about that, double up
the number of output devcies in parallel.
Old 5th January 2004, 02:28 AM   #6
Killjoy99's Avatar
Default Looking at the Leach amp
Thanks for the help everyone. I am trying to contact Professor Leach, regarding the stability of both his Leach amp and SuperLeach amp designs. In the mean time I'm going to double the Output Devices of the Leach Amp as Mr. Pass suggested and see how that comes out.
It's gonna be fun...lol
Old 5th January 2004, 05:30 AM   #7
Killjoy99's Avatar
Default Doubling the number of Output devices
After reviewing the Leach Amp Schematics I am to unfamiliar with this setup to double the output devices. Can anyone help me successfully alter the schematic added double the amount of output devices to improve stability? I'm still trying to understand and learn a lot of the basics here.
Old 5th January 2004, 06:31 AM   #8
Jean is offline Jean  United States
Jean's Avatar
Send a message via AIM to Jean
Maybe Optimos(sp) ?
left lane is for passing, slower traffic keep right please.
Old 5th January 2004, 06:51 AM   #9
Killjoy99's Avatar
Default Optimos(sp)?
I'm not familiar with Optimos(sp). Could you elaborate on it more, please.
Old 5th January 2004, 07:09 AM   #10
Hi
My Symmetrical amplifier will drive that sub @ 400 Watts RMS day in day out.
Cheers
Anthony Holton
www.aussieamplifiers.com
High Power Class G amplifier digitoxin Solid State 30 29th January 2017 11:33 AM
Power amplifier at high frequency Luckyboydtt Chip Amps 18 31st October 2008 08:20 PM
request high power amplifier mohandes_milad Class D 4 23rd August 2005 02:01 PM
High power PA amplifier. halvardf Solid State 3 4th February 2004 05:43 PM
Copyright 1999-2017 diyAudio
