Sansui AU 555a One dead channel ? No power ? - diyAudio
Old 7th March 2014, 01:31 AM   #1
Default Sansui AU 555a One dead channel ? No power ?
Hi. I have read the forum and service manuals and so on...
One channel died after I recapped the amp. I was very careful but now one channel is totally dead. I thought it was a fuse or a bad solder but I started to measure and I noticed there is no power at all from one of the channel from the PSU?! Should it be like that or what could have gone wrong? I'm not that "familiar" with reading schematics ... See the pix attached.
Thanks in advance.
Old 7th March 2014, 02:19 AM   #2
I don't think measuring voltage between fuses will tell us much without knowing what you are trying to tell us there. F002 and F003 are the respective V+ (56V) supplies to either amplifier. You measure the voltage on either side of the fuse to compare the voltage into and out with respect to ground - i.e the neg. lead touching ground. I guess you are saying that one fuse is blown and that channel no longer works? If so, measure the voltage between the supply and amplifier ground, since this is a single supply design and has capacitor output.
The question remains as to what changed values, types and polarity you recapped your amp with and whether modern, larger and low ESR caps simply caused a larger current inrush at start-up, blowing a fuse. A common mistake for unsuspecting new DIYs.
Posting a clear schematic or link to a service manual is good start if you expect others to help:
Sansui AU-555 | Owners/Service Manuals, Schematics, Free Download, Reviews | HiFi Engine
Ian
Old 7th March 2014, 02:23 AM   #3
Did you check the fuses for open? With the meter selector switch in resistance check both end of the fuses. They should read zero ohms resistance.
Old 7th March 2014, 02:48 AM   #4
I downloaded the 555a squematics and those fuses in the pics look like to be an add on as they don't exist either in diagrams or pictures in the service manual.
Also, 2.3V is not a voltage to consider coming from the PS.
If you are lost you should start taking measurements right at transformer input (input AC), then at the transformer output (output AC), then after the rectifier diodes right at the filter caps positive terminal against ground. That will tell if the PS is really working. The 555a PS is really a basic one and you should find this task easy.
Please report back so we can go on from your readings.
Pablo
Old 7th March 2014, 06:05 AM   #5
The fuses are positioned between the power transistors on both 555 and 555A models shown in the service manuals, sextaafondo. However, who knows if mods were required for a model sold over 40 years ago in Sweden, perhaps.
We only need to identy F001 (230VAC) F002 (56VDC left channel output stage) and F003 (56VDC right channel output stage) to find out whether power is available though. Note that an unfused 55V supply is always connected to the rest of the amp. and should always be available for checking, assuming that is not actually the third fuse we see in the pic of this amplifier. !
Ian
Old 7th March 2014, 12:58 PM   #6
Thanks for all help!
I will try some of your hints tonight.
I'm pretty much a newbie so what I wanted to validate is that I had no power on one of the cables coming out from the PS and I find that odd...
So do you guys mean that this fuse holder is a "addon" ? I think it was sold in Sweden but it should have been untouched until I started to recap it.
I didn't messure the fuses but I swapped them left/right and so on and same result so the fuses are ok.
Ian and sextaafondo... Where do I put the multimeter to check this Do I need to open the PS ? Or are there spots I can messure. I can see F002 and F003 but not F001 ... Not sure where to put the multimeter ? Sorry but I need to learn (and ask to learn) =)
Thanks again guys! you really rock!
Old 7th March 2014, 03:26 PM   #7
Just did some new measuring. What I found strange is that C002 and C004 have so different values ?
C819 and C820 = 29.18 and 29.87 V
C001 = 60 V
C002 = 44.8 V
C004 = 25.75 V
C003 = 29.90 V
F002 = 60.8 V
F003 = 60.8 V
All fuses are 0 ohm
Hope someone can give me some other hint here.
Old 7th March 2014, 04:24 PM   #8
Those measurements are OK and say that the PS is working and IMO are within what would be expected though a bit on the high side. Might be due to the AC line being a little high, or due to the power amplifier not draining any current.
It's expected that voltage readings over C002 and C004 are different. Check out the PS desing. There are resistors separating them to provide different PS values.
Ian, and Evilution, regarding those fuses the stock ones as said should be located between the power transistors. The fuses in the first post pic are for sure some sort of repair job on the amplifier. Screenshots from the service manual below.
Some questions now:
Are both channels down, or is sound being amplified normally on one of them?
Have you chequed fuses after removing them from the fuse holders?
Have you got the squematics? In case you don't I attached a copy.
Pablo
Old 7th March 2014, 07:58 PM   #9
Thanks for your replay sextaafondo. Good to hear all voltage are under "control".
Odd. Then I guess its a repair work or Swedish "law" addon... Not sure what it does thou. But strange there are no volt at all on one of the connections?
One channel is totally dead and one is working perfect. Same issue running through speaker A/B and headphones. Fuses have been checked removed and I also switched them left/right.
I got the schematics but this problem is "strange" and I'm not the best to read schematics either ... not sure "what I should be looking for" if you know what I mean ... Could one of the replaced cap be bad and cause this ? A wire loose somewhere ? Don't get it as one channel is dead through the (speaker terminals + phones).
Thanks again, I really appreciate the time you put into my issue here!
Old 7th March 2014, 08:44 PM   #10
There is a fourth fuse for the 6.3 VAC to the pilot lamp. That will not show a reading on a DC scale and though I doubt this is located on the amplifier board, who knows with this extra board? Use a safe AC range to be certain but do not attempt to measure mains AC voltage unless your meter is marked as rated cat. II or better. Hobby DMMs are not and some just burn out on mains AC. Multimeter - Wikipedia, the free encyclopedia.
If this still fails to show a reading, trace the wire supplying the fuse back to its source and find where the power is apparently coming from. Actually, all power to the amplifier comes from the same source, same transformer, same rectifiers etc. The only difference is a few resistors limiting the current to the rest of the amplifiers and any fuses isolating each channel's output stage, as you see.
So , trace the source back by looking, following the schematic and any labels such as B1,B2,B3 etc. which identify the different supplies to the circuit sections I have just discussed. This is pretty self-explanatory when you have the schematic in front of you. Otherwise, you will soon get lost.
Ian
Sansui AU-555A Dead channel argonrepublic Solid State 14 22nd December 2016 09:31 AM
Sansui AU-217 - Weak Left Channel mortron Solid State 0 30th September 2012 06:51 PM
Sansui AU-D11MkII as power amp Forman313 Solid State 2 25th March 2011 07:57 PM
one chan dead on sansui au-4400 amp. dzikamai Solid State 3 17th November 2009 12:44 PM
Sansui Integrated Amp AU 919 No right channel Hanshin Solid State 1 5th April 2009 12:56 PM
Copyright 1999-2017 diyAudio
