Old 24th February 2014, 03:48 PM   #1
Vostro is offline Vostro  Madagascar
Vostro's Avatar
Default bad clipping
Just wanted to know if anyone experienced such bad clipping behavior,
The circuit is a blameless with enhanced vas.
The really bas waveform is without diode D8.
Does anyone have a suggestion as to any changes to improve clipping.
The circuit was just built so many changes to make.
Old 24th February 2014, 03:51 PM   #2
Vostro's Avatar
The circuit
Old 24th February 2014, 03:56 PM   #3
Vostro's Avatar
This is with diode clamp D8 soldered in.
Still not great, but much much better
Old 24th February 2014, 06:13 PM   #4
djoffe is offline djoffe  United States
the shape of the behavior looks about as good as it gets. Is there a 10X factor missing on the scope display for amplitude? the legend implies 2V/box, but the amp's rails look like it should deliver much more swing before clipping.
Old 25th February 2014, 07:18 AM   #5
Vostro's Avatar
The digital display on top showing ch1 P11.24V is peak to peak using a x10 Probe.
Giving a 56V peak output.
Old 25th February 2014, 07:26 AM   #6
peufeu is offline peufeu  France
What you see on the scope is the VAS transistors getting saturated on negative clipping. When coming out of clipping it takes a long time to un-saturate them, which is why the output stays stuck on the negative rail. The diode prevents saturation of VAS transistors, making recovery quicker.
Old 25th February 2014, 07:40 AM   #7
ostripper's Avatar
2 things ...
Why run the CCS at high current ? As well as it also saturating during clip ,
it makes the active half of the VAS "misbehave" more so.
You have a triple EF , 3-5ma VAS I is plenty enough and will run cooler-
less heat and distortion.
10R (R20) as the active VAS Re does not allow Q19 to clamp saturation. With
CM/beta enhancement .. you don't need that low of a Re , try 100-150R instead.
Loop gain of this amp is already high , if you need more .... lower Re on the
LTP or CM instead.
OS
Mongrel website , always current and updated :
http://www.fidelityforce.com/ostripper
Old 25th February 2014, 07:50 AM   #8
dadod is offline dadod  Croatia
dadod's Avatar
Beware, diode connected as this dramatically increases THD.
Old 25th February 2014, 08:01 AM   #9
mcd99uk is offline mcd99uk  United Kingdom
A superior VAS clamp and VAS current limit for the Blameless.
Old 25th February 2014, 08:19 AM   #10
PMA is offline PMA  Europe
PMA's Avatar
Complementary-differential design with symmetrical VAS (no CCS) is the best cure
Pavel Macura
http://web.telecom.cz/macura/audiopage.html
playing bad recordings or bad vinyl gabdx Analogue Source 30 8th February 2013 08:49 PM
Trafo bad, or am I bad caxxxxxx Chip Amps 24 3rd May 2011 08:56 AM
clipping vitalstates Tubes / Valves 2 29th April 2010 10:18 PM
Recovery from clipping, soft clipping hahfran Solid State 49 23rd February 2010 01:03 AM
Clipping richie00boy Class D 2 16th January 2008 05:36 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
