Baxandall Super Pair
Old 11th November 2004, 10:03 AM   #21
Bricolo is offline Bricolo  France
Bricolo's Avatar
I want to know something about this Baxandall super pair
The "control transistor" seems saturated, since it's Vce is approx 0.7V (quite normal; since the control transistor's Vce is equal to the output transistor's Vbe)
Isn't this a problem?
Just remember: in theory there's no difference between theory and practice. But in practice it usually is quite a bit difference... Bob Pease
Old 11th November 2004, 04:18 PM   #22
jcx is offline jcx  United States
not saturated, just not strongly biased
many "current-mode" signal processing circuits bias the cb juntion at ~ 0 V
usually we want more cb bias to reduce Ccb magnitude and modulation with Vcb but in the super pair Vcb is "bootstrapped" by the output transistor to nearly constant voltage so little ac current flows in it , obviously a few V bias wouldn't hurt if it didn't further complicate the circuit
Old 11th November 2004, 04:52 PM   #23
Bricolo's Avatar
OK thank you for the details.
I have an oscillation problem with this super pair, does someone have an idea on how to solve it?
http://www.diyaudio.com/forums/showt...threadid=25051
Old 30th August 2005, 04:23 PM   #24
lumanauw is offline lumanauw  Indonesia
diyAudio Moderator Emeritus
lumanauw's Avatar
Send a message via Yahoo to lumanauw
Hi, JCX,
Is this Super Pair not suitable for audio power amp's VAS because it always oscilate?
What do you think about CFP in place of VAS, why it seldom used in VAS?
Old 30th August 2005, 04:54 PM   #25
somewhere here I showed some R-C damping connections that seem to tame the sims - I've protoed a few super pair circuits but can't claim they will always work without problems - you certainly can't expecct them to be less twitchy than regular cascodes - which can have probelms too
for more vas options:
Originally posted by jcx
see "Gain Stage Investigations" Electronics World, july '98 by Hood
he shows a final config of the VAS as a mirrored diff stage driving a small mosfet common source (no degeneration) that is cascoded with a bipolar to get the max gain from high input impedance at the input to the VAS stage as he assumes a constant load on the VAS from the output stage
the high output Z available from the elaborated cascodes and super-pair enable higher gain if output stage drive impedance can be increased with further buffering - a point that i think can be seen in http://www.ne.jp/asahi/evo/amp/J200K1529/report.htm going from fig 7 to fig 13 (lots of mods but i think the performance couldn't get near these levels without the buffering of the output fet gate impedance)
I believe eva recently reiterated the point that cfp can have complicated clipping behavior/poor recovery - they look really good as long as they're working class A
Old 30th August 2005, 05:20 PM   #26
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
Originally posted by Pedja
Hi Pierre,
Not really 100MHz per MicroCap and neglecting parasitic properties, but it seems like it doesn’t happen accidentally. Try the compensation capacitor (from the base of the first to the collector of the second transistor), say 68pF.
Pedja
Roll off the gain after a couple of MHz - a small cap across I2 should do it.
Jan Didden
Cable: a potential source of trouble interconnecting two other potential sources of trouble - Erik Margan
Linear Audio pubs and articles . The SilentSwitcher now at diyaudio store SilentSwitcher. Keeping in touch with SY.
Old 30th August 2005, 05:21 PM   #27
jan.didden's Avatar
See my previous post.
Jan Didden
Old 3rd March 2007, 02:52 AM   #28
lumanauw's Avatar
This schematic uses superpair for VAS and VAS load. Will this oscilate?
Old 4th March 2007, 04:59 PM   #29
john_ellis is offline john_ellis  United Kingdom
Hi peufeu
going back to the start of this thread ...
the Baxandall pair is an inverter ... so perhaps you just need a small resistance in series with the input with a small Miller capacitor connected from the collector of the output device to the base of the input device.
I'd suggest 1kohms + 10 pF ...
cheers
John
Old 4th March 2007, 09:11 PM   #30
Terry Demol is offline Terry Demol  Australia
Terry Demol's Avatar
What does the OP stage look like?
Terry
Baxandall Super PairHide this!Advertise here!
FS: Tonegen/Tonigen Ribbon super tweeters PAIR Antripodean Swap Meet 4 24th April 2012 12:53 PM
FS - Super Helix Gold SC - 8' pair hafp Swap Meet 0 15th July 2009 08:56 PM
DIY Baxandall network Craig405 Solid State 5 3rd September 2005 10:04 AM
Baxandall Eq brianti Analogue Source 3 2nd November 2004 02:38 AM
3-band Baxandall BoGoMiPz Solid State 0 28th February 2002 11:49 AM
