Experiencing a mysterious hum in a Parasound HCA-2200 II.
Old 16th February 2014, 05:35 AM   #1
nickrobotron is offline nickrobotron  United States
Default Experiencing a mysterious hum in a Parasound HCA-2200 II.
I have a hum that comes through the speakers. It doesn't change when I adjust the volume control, but it does get slightly louder as the amp warms up.
I read the manual and tried to bypass the ground with a cheater plug. No luck. So I took it to an authorized Parasound technician and he said he couldn't hear the issue. I figured it was the power at my house. Since then I have tried it at 4 different houses and the same thing happens everywhere.
I don't think the tech was lying. I honestly believe he couldn't hear it. It's pretty subtle. The tech says that he tested capacitors and everything was in spec.
Any ideas? Can someone help me out with a schematic? I'd like to be loaded with information for when I take it to a different tech.
BTW, this is my first post here. I am an active member at AudioKarma, but thought I'd branch out and try for help here. To say that I am a novice would be an understatement. I may not fully understand your advice, haha, but maybe I can take some of it to the tech.
Nick
Old 18th February 2014, 01:18 AM   #2
Any tips or advice out there?
Old 18th February 2014, 02:18 AM   #3
EchoWars is offline EchoWars  United States
EchoWars's Avatar
I saw a schematic for the original 2200 here somewhere, but I don't think it was complete, and I don't know what the differences are.
Isn't this a JC design? Any info out there on this amp guys?
Old 23rd February 2014, 04:09 AM   #4
embrown057 is offline embrown057  United States
It would help if we knew if you had a 120hz or 60hz hum. Also do you have the jumper pin on the XLR connectors? As far as the power supply caps, I have not seen one of them test good. I have rebuilt several first ver's and MKII all in need of re-cap and power resistors. Another problem is the poor soldering done by the Chinese. I have seen more than one lead barely soldered in of just plane broken loose. Also check ALL of the connections to the main caps and grounds. Even though they have sealant on them I still find them loose. If you need the schematic let me know. I have posted somewhere the BIAS setting procedure, just do a search.
Old 23rd February 2014, 07:10 AM   #5
LineSource is offline LineSource  United States
LineSource's Avatar
The attached Google'ed schematic is for revision I HCA-2200 amps. Information from Parasound states that are no major circuit topology changes for your revision II, mainly a better PCB layout.
When you ground both amplifier inputs, do you hear a hum? 60Hz? If both channels hum, the shared main power supply is a good place to start measurements, and checks for a loose ground connection.
With one input grounded, and one input connected to your preamp, do you hear a hum? Alternate inputs? Good suggestion to remove+plug+remove+plug scrub clean the jumper pins on the XLR connectors?
Can you test the amp with an alternate input source? Capacitor coupled or battery powered?
Old 23rd February 2014, 07:15 PM   #6
Here's the difference from original 2200 and MKII. I posted this some time ago. Came directly from Tony:
http://www.diyaudio.com/forums/solid...0-mark-ll.html
Old 26th February 2014, 08:51 AM   #7
EchoWars's Avatar
That's the scat I was looking for...
Need some feedback from OP to go any further.
Oh, and thank's Ed...this one might end up on my bench, so your input is appreciated.
Experiencing a mysterious hum in a Parasound HCA-2200 II.Hide this!Advertise here!
Parasound HCA-2200 problem - need some help Muddler Solid State 13 29th August 2013 09:50 AM
Parasound HCA 2200 Mk II strange behaviour EspenE Solid State 5 25th February 2012 11:44 PM
Parasound HCA-2200 II Fuses movinginstereo Solid State 0 3rd December 2009 03:31 AM
Parasound HCA-2200 II repair question cocolino Solid State 10 6th September 2008 07:45 AM
Need Schematic for Parasound HCA 2200 II mjctech Solid State 2 15th September 2005 04:25 PM
