Leak Delta 70
Leak Delta 70
Old 14th February 2014, 06:18 PM   #1
Tony83 is offline Tony83
Default Leak Delta 70
my delta 70 was running OK then one channel suddenly became very very loud. I could only use the amlifier with the balance contol fully clockwise. I isolated the fault to one plug-in board (not the pre-amp board). I have the circuit diagram, but need help to pin poibt the faulty component. I have checked the board for bad solder joints. Any suggestions please.
Old 14th February 2014, 06:27 PM   #2
Mooly's Avatar
Leak Delta 70
We would need to see the circuit for sure. Strange fault... could it be a floating ground to the volume control such that there is no attenuation on that channel... or a faulty control.
Old 14th February 2014, 06:32 PM   #3
ashok is offline ashok
ashok's Avatar
Leak Delta 70
Hopefully the negative feedback doesn't go through the pins of the pcb sockets!
Tony83: How was the sound ( when it was working well) ? A modern version with newer transistors sounds quite good.
What speakers are you using?
Cheers.
AM
Old 14th February 2014, 06:52 PM   #4
Mooly's Avatar
Leak Delta 70
Looks like the NFB does go through the sockets. Lol... at least they are in the loop
Make sure (measure on ohms range with amp OFF) that point "A" (measure on R36) goes down to virtually zero ohms at minimum volume. Check that R48 is OK and that all the plus/sockets are good. Many of the electroylitics will be getting past it too and it would all benefit from a re-cap... but find the fault first.
Edit... measure the resistance above with respect to ground (the thick black line).
Leak Delta 70Hide this!Advertise here!
Leak Delta 70 with MOSFET output stage ashok Solid State 9 6th January 2018 04:57 PM
leak delta 70 Tony83 Introductions 4 12th February 2014 08:43 PM
Leak Delta 70 - No Sound/Buzzing eddiedynamite Solid State 0 10th February 2013 03:36 PM
Another Leak Delta 70 maintenance thread. steenamaroo Solid State 17 4th September 2012 06:52 PM
Leak Stereo 30+, Stereo 70 & Delta 70 (UK sale) Tweedle12 Swap Meet 2 13th April 2012 11:32 PM
