Hi all, i have a NAIT 5 amplifier and im trying to run this as a pre amp with some meridian power amps that i inherited of my father who passed away 3 weeks ago. but im having a problem, i removed the link and made the appropriate 4 pin din but the naim does not power up. This is because it has a pin that is + voltage., if i was using a NAP150 this would power the pre amp section on the NAIT 5. Any ideas people??
thanks Richard
thanks Richard
You may get the whole Nait, Flatcap PSU, Snaic cables routine that goes with these products at pinkfishmedia forum. Unfortunately, the brand has long been a way to spend a lot of cash on partial solutions to the most fundamental requirements of powering and connecting audio products together. I'm guessing you've already seen the user manual. Check page 8 showing Nait as preamp.
http://www.naimaudio.com/sites/defa...ads/files/old_product_manual_nait5_manual.pdf
Joined 2009
thanks Richard
Sorry to hear about your father Richard. I hope those Meridian amps will be a good reminder of the good times.
