Old 1st March 2002, 07:28 PM   #11
Banned
Hairy Holler:
You may be right for HFQs and the like. They probably have lower ESL. There is a place for skinny ones here, and they do come in handy as decoupling. Especially for digital stuff.
Unless you can afford those expensive carbon types.
I was refering to filter caps. 10,000 uF and up types.
Yep, that amp I built with skinny caps had no bottom at all. Not my plate of shrimp..........
Old 2nd March 2002, 02:26 AM   #12
Lisandro_P's Avatar
Send a message via ICQ to Lisandro_P
A few things no one mentioned, i think.... using multiple caps have other advantages besides ESR and the works.
- 1. More voltages rating available on smaller caps than bigger ones. This came in handy for me, as my PSU delivers 22vdc, so i was able to order 35v caps instead of the "regular" 50v ones and save quite a few bucks. The bigger "can" caps came only in 50v and 100v ratings.
-2. Smaller caps are cheaper than a bigger cap at the same capacitance. I didn't expect this, but it is so My cap-x power supplies has 54,400 uF in total, and that costed me $40; about 1300uF per buck (not counting bypass caps included in that too). Not bad!
Old 2nd March 2002, 03:20 PM   #13
promitheus's Avatar
Normally alot of small caps cost less at the same capacitance. But you have to remember that you need a lot more work and maybe a heavy duty pcb to carry all the caps. I like a lot more small caps than 1-2 big ones. But you DO have to know the specs of them because it is very important when designing.
Just one big filter cap or more smaller filter caps ... beppe61 Power Supplies 2 18th July 2006 05:46 PM
Can I replace Samhwa caps in PS with smaller value ones of better quality ? Elberoth Solid State 1 9th January 2005 07:16 AM
Are Parallel smaller caps better/worse than big? Arx Parts 4 9th November 2003 10:54 PM
smaller caps punchpeanut Chip Amps 0 27th August 2003 01:59 PM
Getting Smaller pinkmouse Chip Amps 6 21st July 2003 02:11 PM
Page generated in 0.07498 seconds (71.66% PHP - 28.34% MySQL) with 10 queries
