4db output from -15db professional audio from user, amplifer help please
Old 3rd January 2004, 10:54 PM   #11
usekgb is offline usekgb  United States
usekgb's Avatar
The DRV134 will give you better performance than the 5532 layout due to the fact that all of the resistors required to set the gain of the op-amps are internal and laser trimmed in the DRV134. So, in reality, using the DRV134 will be cheaper, use less parts, and will give better performance.
Zach
Old 4th January 2004, 09:41 AM   #12
moamps is offline moamps  Croatia
Yes, but this isn't here on first place of priority. Daniel needs moderate quality preamp with 20dB gain; the DRV134 hasn't gain.(I use AD SSM 2142 for high quality applications).
Old 4th January 2004, 10:04 AM   #13
dhaen is offline dhaen  Europe
diyAudio Moderator Emeritus
dhaen's Avatar
Actually, you can get gain out of a DRV134 by inserting resistors in pins 2 & 7, but as I intimated earlier, it will start to degradr the performance.
Moamps solution is elegant.
I believe you need "golden ears" to tell the DRV134 and SSM2142 apart. To me they're functionally equivalent.
Old 4th January 2004, 10:09 AM   #14
traderbam is offline traderbam  Europe
traderbam's Avatar
Moamps,
Have you considered arranging the opamps in parallel rather than in series in order to achieve a more accurately balanced output?
In your diagram you would disconnect R5 from the o/p if IC1A and connect it to pin 3 of IC1A, then remove R1 completely.
Old 4th January 2004, 11:11 AM   #15
this is another possibility, but you must change resistors values to get the same gain in two topologies (noninverting and inverting opamps). Those values are then outside the E24 range, etc..
regards
Old 4th January 2004, 12:14 PM   #16
RobWells is offline RobWells  United Kingdom
RobWells's Avatar
Hi all,
I was looking for something like Moamps' circuit to up the sub out level of my av receiver into a behringer ultracurve pro. (then onto pro amps)
I have opa 2134's lying about here, and a power supply already built. Can I use these instead of the 5532 ? - I read elsewhere on the forum that the 5532 will handle a higher voltage.
Cheers
Rob
Old 4th January 2004, 02:28 PM   #17
dhaen's Avatar
Rob,
The 2134 is a different animal. But practically any opamp will work. It depends on how good you want it to be. If you want the best, then go for the dedicated chip DRV134.
Oh, the datasheet say the 2143'll take + - 18v.
Old 4th January 2004, 02:33 PM   #18
RobWells's Avatar
Hi John,
Would the DRV134 drop straight into the above circuit or do I need a new one? - You know that electronics ain't my forte
Cheers
rob
Old 4th January 2004, 03:21 PM   #19
dhaen's Avatar
Default Bak sheesh
No Rob.
Drop me an email with your address, and I'll pop a 5532 in the post.
Old 4th January 2004, 03:33 PM   #20
RobWells's Avatar
Cheers John but...,
I've added a couple of them to an order I've just placed. How different would a 'proper' circuit be in complexity ? I've got a few transformers lying around and am looking for a UK supplier of the DRV134 right now. Can probably adapt the power supply I've got at the mo : http://sound.westhost.com/project05.htm
I'll do a search for the DRV cicuits and see what I find.
EDIT: found this : http://www.jensen-transformers.com/as/as022.pdf
Has an option without transformers...(not drv134 though)
Cheers
Rob
4db output from -15db professional audio from user, amplifer help pleaseHide this!Advertise here!
FET audio amplifier - the best amplifer donpetru Solid State 22 20th December 2007 07:29 AM
Professional EQs in Home Audio Ric_LV Music 9 9th July 2006 07:13 PM
Professional EQs in Home Audio Ric_LV Everything Else 2 1st May 2006 01:26 PM
