Good 300 W 8 Ohm power amplifier - diyAudio
Old 30th December 2003, 09:17 AM   #1
darkm4n is offline darkm4n  Romania
darkm4n's Avatar
Send a message via ICQ to darkm4n Send a message via MSN to darkm4n Send a message via Yahoo to darkm4n
Default Good 300 W 8 Ohm power amplifier .
Hi , anyone here know a good 300 W 8 Ohm minim power amplifier ?
I'am searching for something not very hard to build and not very expensive...
Thank's !
Old 30th December 2003, 09:56 AM   #2
darkm4n's Avatar
Default Hi again ...
Maybe P3A from sound.westhost.com it's good for me ..
Someone know a layout for this amplifier ? ( PCB )
Old 30th December 2003, 10:30 AM   #3
Default 300 Watt Amp
Build the ESP P68 , I am presently running 4 in a club and they really kick butt, easy to build and Rod's boards are very well made.
Old 30th December 2003, 10:38 AM   #4
Default hi
you can build the elektor trans 300 w amp , using mj 2 x 15003 and 2 x mj 15004 in the out put stage , requirs about 650 va or so
Old 30th December 2003, 11:20 AM   #5
Workhorse's Avatar
300W @4 ohms
OR
300W @8 ohms
Plz Clarify
Old 30th December 2003, 12:30 PM   #6
bawang is offline bawang  Malaysia
Or, try the Superleach amp at around 270W into 8 ohms, about double this into 4 ohms at Prof. Leach's website. A search for "Leach Amplifier" will produce results....
Old 30th December 2003, 12:39 PM   #7
darkm4n's Avatar
300 W in 8 Ohm .
I can't build the Leach amp .. i can't find some transistors here in romania .. i relly like that amp .. well documented .. very good design .
What about the elekton amp ? someone mention about this one upper in this tread ...
Also .. maybe P68 is a good idee .
Thank's !
Old 30th December 2003, 12:56 PM   #8
Workhorse's Avatar
Default Elektor amp
The elektor amp features as follows
+-65VDC @625VA transformer
Although a Symmetrical design PA300 W
Frontend consists of Ne5534 Opamp served as diffrential amp
Voltage amplification and current drive is achieved by MJE15032 and MJE15033 drivers and output stage consists of 2 X MJ15024 and MJ15023 devices
A descent design by Riedl
Disadvantages
Requires too much heat sinking or u have to use force cooling
low slew rate
medium damping factor
Old 30th December 2003, 06:04 PM   #9
darkm4n's Avatar
Default Hmm...
Maybe ... what you would recomand me ?
Old 30th December 2003, 07:15 PM   #10
Account Disabled
Default Re: Elektor amp
Originally posted by darkm4n
i can't find some transistors here in romania.
Thank's !
you don't have to have the exact transistors. Just find the datasheet for the transistors used and find their equavalents in your country.
thanks like an interesting design. do you have a schematics for it?
A good tube amplifier power supply Jean-Paul_2 Tubes / Valves 23 18th June 2009 11:19 PM
Is this transformer good for power amplifier ostie01 Solid State 10 14th August 2006 02:53 PM
A good Brazilian Amplifier, class A switching to AB in hi power destroyer X Solid State 65 24th March 2005 08:12 PM
Lowering gain of power amplifier, good idea? squadra Solid State 10 5th May 2004 03:43 PM
good battery for amplifier power supply? cowanrg Parts 0 20th September 2003 11:47 PM
Copyright 1999-2017 diyAudio
