Gamut amplifier - diyAudio
Old 27th February 2002, 09:30 AM   #1
jouch is offline jouch  Sweden
Question Gamut amplifier
I'm wondering I some body have some informations about Gamut amplifier.
The construction and circuit seem to be realy easy, they only use two mosfet per channel.
But that's all I know.
Christopher
Old 27th February 2002, 10:38 AM   #2
All I know is that high power MOSFET's modules in a so-called Mini-Bloc (SOT-277) package are used.
The schematic would be rather similar to an upscaled aleph or so, I think...
Old 27th February 2002, 01:55 PM   #3
So I suppose I should use the same architecture as one an Aleph, but change the out put stage with this block?
Christopher
Old 27th February 2002, 06:36 PM   #4
The one and only
Nelson Pass's Avatar
Certainly you can give it a try. I have built some
Alephs and Zens with the IR TO-240A packages,
and the 500 watt rating is certainly attractive. They
consist of 4 regular sized power chips arranged in
parallel or series/parallel depending on the part.
However...
These are 10 times more expensive than a single
device at 200 watts, which while not a consideration
for me, (mine were samples) will not be ignored by
most everybody else.
and...
You cannot assume the level of matching of the
parts as it appears that they are intended for
switching applications, where Vgs matching is
not so important.
nevertheless.....
These are cool looking industrial parts, and you'll
be the envy of all your DIY buddies.
Old 28th February 2002, 01:19 AM   #5
lohk is offline lohk  Europe
lohk's Avatar
What about the Greenwall amplifiers ?
They look like a complete ZEN family ripoff.
Old 28th February 2002, 07:52 AM   #6
Talking greenwall amps
Hallo,
had a close look at the greenwall amps. They are Zen Amps. Look at www.greenwall.de
Reinhard
Old 28th February 2002, 07:03 PM   #7
The one and only
They aren't the first. A certain outfit in
North Carolina also plagiarized the Zen.
Old 28th February 2002, 07:12 PM   #8
Banned
Default Zen
And they even have a link to Passlabs on thier site!
H.H.
Old 8th August 2012, 02:38 PM   #9
tiefbassuebertr's Avatar
Originally Posted by reinhard View Post
Hallo,
had a close look at the greenwall amps. They are Zen Amps. Look at www.greenwall.de (www_greenwall_de)
Reinhard
Unfortunately this URL don't goes open.
Old 8th August 2012, 02:59 PM   #10
Banned
M250I, monoblock amplifier that I can make by myself.
Anadigit
Gamut D200 clone !!! ANALOG GUY Solid State 71 10th July 2014 05:32 AM
FS:GAMUT D200 MKIII clone kit ANALOG GUY Swap Meet 17 3rd March 2008 12:10 PM
Fs: Gamut D200 Mkiii ANALOG GUY Swap Meet 1 18th June 2007 04:33 AM
Gamut audio ben goh Pass Labs 14 5th March 2007 10:32 AM
gamut amp brian t Solid State 1 10th August 2002 11:37 AM
Copyright ©1999-2017 diyAudio
