Upping the Watts - diyAudio
Old 20th January 2014, 01:28 PM   #1
Default Upping the Watts
just sent for a chinese JLH 10 watt amplifier kit.
I intend to see what it sounds like using better parts than come with the kit.
The power transistors are 2n3005. I think these can take quite a large voltage.
My question is can the wattage be increased and how would I do it.
Is it just more DC voltage in and higher rated caps etc.
cheers and Happy New Year.
Old 20th January 2014, 01:32 PM   #2
Did it Himself
richie00boy's Avatar
No, it's the power rating not the voltage that is the problem.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, modules and more.
Old 20th January 2014, 01:34 PM   #3
So if I stick more amps into it I should get a wattage increase.
Old 20th January 2014, 01:37 PM   #4
hi,
My favourite output transistors are MJ15003 so they will be fitted.
Old 20th January 2014, 01:45 PM   #5
Did it Himself
No.
Read up on some basics about electronics. Check out Rod Elliot's ESP site which has some good articles from basics about amplifiers and electronics.
For now, just build the amp as it's meant to be. Putting faster transistors in might introduce instability. When you understand a bit more then you can play about with it. Nothing worse than trying to get a kit working when you don't know.
Old 20th January 2014, 02:27 PM   #6
hi ritchie,
Built plenty, Including kits from Rob down under, but must admit I am lazy about theory.
These Chinese amps have dubious parts so I intended to pick better parts to see how it sounds before I solder inferior parts in.
Just wondered what held this amp back to 10 watts.
Old 20th January 2014, 02:38 PM   #7
hi ritchie, your post came through to my email unedited.
I do have a clue about what I'm doing, repaired Exposure amps repaired Linn amps, built other JLH designs Chiarra pre amp power supplies etc. Built a pair of Isobariks from scratch!!!! Been swapping systems for 40 years.
Had a couple of magic smoke incidents but haven't we all.
As I asked, just unclear regarding the theory of output wattages.
I will read.
cheers
Old 20th January 2014, 03:04 PM   #8
Did it Himself
Have a look and don't be afraid to ask any questions here.
Old 20th January 2014, 03:05 PM   #9
Hi
there is a table featured in an update to the original design that seems to suggest that the output wattage is dependant upon the input voltage of the transformer. As the input voltage rises the output wattage rises.
The Class-A Amplifier Site - JLH Class-A Update
a secondary voltage of 30v will give 60 watts into 8 ohms.
Could I stand corrected or is that my original thought from my post.
Old 20th January 2014, 03:37 PM   #10
still4given's Avatar
Which kit are you buying? The one in the article you linked to is the 1996 version with dual rails. Is that the one you are building? There is also the 1969 version that uses a single rail supply.
ucd 25 watts to 1200 watts using 2 mosfets andrewlebon Class D 4591 Yesterday 11:01 AM
Upping voltage on a toroid carlmart Solid State 7 1st September 2007 10:56 AM
Sound quality of amps at 0.3 watts vs @ typical 5 watts rick57 Solid State 2 26th March 2005 06:25 AM
Upping the bias on Aleph 2 Mark A. Gulbrandsen Pass Labs 15 15th November 2003 07:16 PM
Copyright ©1999-2017 diyAudio
