Ideas to what might cause almost full supply voltage DC offset? - Page 2 - diyAudio
Old 19th January 2014, 03:54 PM   #11
Welcome is offline Welcome  France
Welcome's Avatar
I've already checked all the transistors (out of circuit), and they all work.
Now I've done the following:
Disconnect everything that takes power from the supply, minus the B+ and B- going to the power amp (that means the phono amp, pre amp and tuner are not getting any power).
Move input signal from volume control directly into power amp.
Now the B+ voltage still goes down to 0V a couple of minutes after power down, whereas the B- stays at about full voltage.
DC offset is now 16VDC. A quick five second test reveals: Some hiss through the speaker (DC offset of course) but music plays nice and clear. Robust speaker, that. Started smelling again.
Old 19th January 2014, 04:29 PM   #12
Welcome's Avatar
How embarrassing.
I somehow managed to miss one small TO-92 transistor (Q403 if anyone cares), and of course - it was the culprit. It was open in all the directions.
Preliminary testing: having replaced that garners about 1mV offset (with new diff pair transistors), and music plays fine through headphones. I will stitch everything back to normal now (it's a mess) and see if it still works after.
Thanks for your thoughts, everyone. Greatly appreciated.
Old 20th January 2014, 11:07 AM   #13
tvrgeek is offline tvrgeek  United States
We will now all enjoy a laugh at your expense, because we ALL have been there!
Old 20th January 2014, 04:32 PM   #14
still4given's Avatar
Just a note from my meager experience, when you see + dc voltage on the output, it usually indicates that something on the - side of the circuit is not functioning. Either a busted transistor of an open resistor. That also accounts for the + rail draining more quickly than the - rail on shutdown.
Old 20th January 2014, 05:32 PM   #15
east electronics's Avatar
+++10000 very correct Often people that see + Dc offset in the output run for NPN transistors in the output stage or drivers ...while the real fault is an open resistor on the other side
Well said still4given !
Kind regards
Sakis
SERVICE ΕΝΙΣΧΥΤΩΝ ΚΑΙ ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr
Voltage effects on DC offset and bias albertNL Pass Labs 15 5th March 2012 02:28 PM
Aleph 3: rail voltage as dc offset uvellani Pass Labs 2 28th November 2010 03:04 PM
Acceptable DC offset voltage hags Chip Amps 2 8th March 2007 10:56 AM
DC Offset voltage phil Solid State 3 23rd October 2001 06:37 AM
DC offset voltage? harbin Solid State 2 13th June 2001 06:51 PM
Copyright 1999-2017 diyAudio
