yamaha rx-v2095 wont power on
Old 20th January 2014, 02:43 PM   #11
tauro0221 is offline tauro0221  United States
Read page 10 of the manual. I think it explained what it is happening to your amplifier. The question it is if when this it is happening you can go to the diag. and it will show the problem. I still think that it is a problem with one of the channel output.
Old 20th January 2014, 03:42 PM   #12
srinath is offline srinath  United States
I will try 1 channel at a time.
Cool.
Srinath.
Old 20th January 2014, 04:34 PM   #13
Another thing has to do with the shutdown it is the PRV signal. It indicated that you have a problem with one of the power supplies. All power supplies voltages are tied to a point and the signal goes to the micro IC3. PRV it is pin 65 for the IC3 and it is located in page 68 to the right of the page. It should be + 5 volt = 1 to the micro processor.
Old 20th January 2014, 06:05 PM   #14
Main left a and b flashed like .03v DC at startup and for a second or 2 later. All the rest showed 0.
What is PRV signal. Also I am not finding the IC3 chip at all.
Cool.
Srinath.
Old 20th January 2014, 06:13 PM   #15
OK I found the chip mentioned in the page 68. Its on the front panel back side. But there is 2 of them. Which one ? and I'll try to test both.
Thanks.
Srinath.
Old 20th January 2014, 06:13 PM   #16
Pin 65 and 68 - The chip only has 49. I think.
1 sec. Let me check.
Thanks.
Srinath.
Old 20th January 2014, 06:18 PM   #17
64 pins in LC757. I am looking to see what you are refering to.
Thanks.
Srinath.
Old 20th January 2014, 06:29 PM   #18
Sorry it is in page 64 Main micro. IC3 pin 65. It should be high on power on.
Old 20th January 2014, 06:41 PM   #19
That chip I am still looking for, where did it disappear.
Anyway on that main board I have what looks like a burnt q127.
Thanks so much tauro0221. You've helped me with other amps too in the past, like my HK 7000 and onkyo 805.
Thanks a million. I am a motorcycle hobby mechanic, if you were to have a motorcycle issue let me know, I'll see if I cant help you fix it the way you have helped me.
Cool.
Srinath.
Old 20th January 2014, 07:20 PM   #20
Ok I found connection 81 and center pin which is connected to leg 65 of IC3. I get a 2v dc or there about flash @ power up. Still looking for IC3 though. Grrrrrr.
Thanks.
Srinath.
yamaha rx-v2095 wont power onHide this!Advertise here!
Yamaha RX-V2600 does not power up paul_peraic Solid State 25 26th August 2015 12:55 AM
Yamaha M-65 wont power on Rob B Solid State 11 20th March 2013 12:27 AM
Yamaha RX-V367 thetube0a3 Digital Source 0 28th November 2012 06:19 PM
Yamaha RX-730 power issues Smoothjazz Solid State 6 21st November 2012 04:22 AM
Yamaha RX-V800 wont turn on serafis Solid State 4 28th June 2008 01:16 PM
Copyright ©1999-2017 diyAudio
