How to optimize this CFA? - diyAudio
Old 15th January 2014, 04:02 AM   #1
bimo is offline bimo  Indonesia
bimo's Avatar
Default How to optimize this CFA?
I have build VSSA and then inspire by Lazy Cat who achieve 0,0001% THD at 1kHz, 1W/8Ohm with his First One, I want to modify my VSSA.
Please help me to optimize this design for lower THD and to make stable. I want to make this design as simple as possible. Any suggestion are welcome.
Anistardi
Old 15th January 2014, 04:20 AM   #2
ostripper's Avatar
It's a CFA , needs regulation /CCS's .. no way around it.
It's 2 big caps make THD .01% at 20hz. No way around that without
a servo. HF is extraordinary, PPM all the way to 100k.
Below is what I settled on for this design. It will be my second CFA
IPS. (with servo)
PS - make stable ???? It will run with NO compensation ...
Also , heck with the "THD fetish" , I want PSRR , no drift/DC , run cool and to last for 20 years.
.001% and below is a good target.
OS
Wanderer - my travels.... Facebook - davyjones lockre -
Old 15th January 2014, 04:36 AM   #3
bimo's Avatar
IPS. (with servo)
OS
I want to trade THD 20 Hz for simplicities. Btw, my ears more sensitive at high freq . May be I add capacitance multiplier for IPS.
Old 15th January 2014, 04:42 AM   #4
ostripper's Avatar
Yes , C mult. is "big one" ... CCS is also a real game changer.
Actually , the VSSA is the best of my simulated CFA's for LF WITH caps.
(.006% 20hz -2200u caps) ....
OS
Old 15th January 2014, 05:31 AM   #5
bimo's Avatar
OS
But this is 0.000363% at 12Vp.
Old 15th January 2014, 08:01 AM   #6
bimo's Avatar
Default VSSA with 3EF
I change the OPS with 3EF.
To get lowest THD, the VAS current is around 13-14mA for all OPS. CCS setting is tricky.
Old 15th January 2014, 12:14 PM   #7
bimo's Avatar
Almost finish. Very low THD
Old 15th January 2014, 12:33 PM   #8
bimo's Avatar
With optimize bias current of output transistors, it give:
121W/8Ohm, 1kHz, 0.000076%
121W/8Ohm, 20kHz, 0.000559%
If implemented correctly, I'm sure it will comparable to LC's First One .
I was finished to draw OPS PCB like OS's style. But I must make some software for my friend now.
Old 17th January 2014, 08:16 AM   #9
bimo's Avatar
Inspire by OS, I draw the OPS. I already send the file to PCB maker.
Old 17th January 2014, 08:27 AM   #10
bimo's Avatar
... and the IPS.
measuring impedance to optimize horn chamber Milkduds Multi-Way 8 12th January 2012 08:03 PM
Current Source <- how to optimize? EE Solid State 85 2nd May 2010 09:08 PM
Using genetic algorithms to optimize pentode parameters Bitrex Tubes / Valves 2 14th February 2009 06:21 PM
how to optimize this pentode PP (PP1 clone with S11E12) Jaap Tubes / Valves 3 13th December 2008 01:12 PM
Please help me, to optimize this driver for TL sub christophorus Subwoofers 3 14th January 2007 11:41 AM
Copyright 1999-2017 diyAudio
