Old 28th December 2003, 08:36 PM   #1
Ryssen is offline Ryssen  Sweden
Ryssen's Avatar
Default Can I use a SIL relay ?
Can I use a SIL relay for audio signals or is it better to use a regular one?
Old 28th December 2003, 09:15 PM   #2
Electrons are yellow and more is better!
peranders's Avatar
If you want to switch small signals you must choose a signal relay, not a power relay. The shape isn't important but the intended usage is.
A power relay must have 10 mA trought the contacts in order to work good. They also need a minimum voltage.
/Per-Anders (my first name) or P-A as my friends call me
Old 28th December 2003, 10:01 PM   #3
djmiddelkoop's Avatar
while we are at it,
what do you think about mercury wetted relays ?
Because the contact is made through a drop of mercury, it is very reliable for small signals.
As long as it is not destroyed by too much current, this is probably the best way to make a contact.
The only thing that I don't like is the magnetic field through the contacts to put the mercury in position to make the contact.
As we all know magnetic materials and fields influence the signal(current).
Dick.
Music is the best F.Z.
Old 29th December 2003, 02:37 PM   #4
well , mercury is actually diamagnetic, i e it creates a very small magnetic field by the opposite vector when subjected to an external magnetic field. it is not strong enogh to "move" the mercury unless insanely strong magnetic fields are used (but then the rivet buttons in your jeans tend to follow to...)
therefore mercury wetted relays dont operate by magnetic force to move the
mercury, but rather a magnetic material like iron, which is one of the contacts. the other is the mercury itself.
this is used in some high power relays , since it is quite unsensitive to arcing, but have been succeded by other ways of high power switching.
the typical use for a mercury relay is however a tilt relay , where a drop of mercury is "flowable" inside the body of the relay and depending on position, creates contact or not. it would be a bit awkward to tilt the preamp each time you want to change channel
and yes, I totally agree with peranders.
/rickard
listen! Can you hear that ...
Old 29th December 2003, 04:52 PM   #5
Thanks Rickard for your detailed info.
Yes, mercury is widely used in power-relays.
But, if you look carefully at manufactures like Clare, they have a number of small mercury wetted relays with 0.005 Ohm contact resistance.
I have found quite a number of these relays at electronic dumps.
They can easily be recognised by the arrow pointing in the way they should be mounted.
I have seen them also in the industry on PCB's where small signals switching occurs.
So, my question is still are they suitable for high quality audio regarding the magnetic field needed to make the contact ?
Old 29th December 2003, 05:47 PM   #6
peranders's Avatar
I think we all can forget about relays with mercury wetted contacts because they are forbidden to sell. You need special permit to buy these.
Old 29th December 2003, 07:14 PM   #7
actually peranders, that depends on which country you live in. perhaps in holland (as I asume is dj_koops homeland) it is still legal?
In sweden all selling,use or discarding of metallic mercury in any form will be banned from 2004 or 2005 i think. This is also true for most mercuric compounds.
by the latest of 2020 all mercury will be collected , transformed into mercuric sulfide (insoluble, ak a mineral cinnober)
and stuffed away in the ground, not unlike nuclear waste. Back to topic...
Anyway, _koop, you are right. I mixed up a couple of different relays. I actually googled a bit and found out that I was (partially) wrong.
As far as I understand it, mercury wetted relays use mercury as a contact material,(probably to improve debouncing) , and also by reducing contact resistance (it is a liquid, filling out all "gaps) but the moving part is still some sort of solid conductor, moved by a magnetic material with a magnetic field, since a magnetic field doesnt affect mercury very much physically.
So I dont think that any magnetic field would influence the signal any worse than a normal relay.
By taking the the environmental issue in consideration , which by me would be the most important technical factor here I would rather use a designated small signal relay
/rickard
Old 29th December 2003, 10:23 PM   #8
Thanks again Rickard,
your replay is the answer to my question
About the environmental issue of mercury here in Holland, I really wouldn't know, and I wouldn't be surprised that it's forbidden to.
Anyway, as said before, I have seen them around.
Added to the excellent reply of Rickard, one other great advantage of mercury wetted relays is their reliability over the years. As long as the coil doesn't burn, it will make a good contact forever if switching signals.
But as these relays are hard to get, I also recommend a small signal relay over every other big relay, if switching signals.
Dick.
Old 29th December 2003, 10:45 PM   #9
you are welcome
/rickard
Relay hugobors Parts 6 21st February 2006 10:20 AM
Looking for the best relay carlmart Solid State 15 19th August 2005 12:06 AM
Connecting a relay DragonMaster Everything Else 8 3rd March 2005 09:38 PM
Help with relay ppereira Solid State 14 21st June 2003 08:10 AM
Relay or not relay ? Yonnat Pass Labs 10 10th April 2003 07:26 PM
Page generated in 0.09256 seconds (87.81% PHP - 12.19% MySQL) with 10 queries
