Alesis RA150 burns power resistor
Old 11th January 2014, 12:35 PM   #1
starcaribe is offline starcaribe
Default Alesis RA150 burns power resistor
Hi All,
I am new to audio electronics tinkering and hope my diyAudio participation proves valuable to others as well.
Jumping right in: My recently repaired Alesis RA150 worked for 2 wks then quit, again burning out the power resistor.
What happened: Heard a “click” thru spks, volume increased on its own, “searing” noise thru spks, sound died amid smoke.
What I found: 1. Mains Fuse burned; 2. R401 (470/2W) burned; 3. C403 (220uf) bulging at top but testing normal with analog vom; 4. Z1 (15V) shorted.
Repair Status: Changed those 4 parts and reconnected LED indicator circuit, Driver amps and Pwr amps to Pwr Supply board one at a time.
Bench running at low volume for a couple hours now. DC at spk terminals: Rt – 0.1mV Lt – 0.5mV
Question: What else should I check and/or replace before putting amp back in service? Previous fix included change of all el’tic caps except main filters and 2 in the LED circuit. Schematics can be viewed here http://forum.vegalab.ru/attachment.p...mentid=75690&d
Big thanks.
Mort
Old 18th January 2014, 12:59 PM   #2
Default Update to Alesis ra150 burns resistor
Update on Alesis RA150:
Bench run unit for 6-10 hrs daily since replacing 470R and zener.
Rigged 12 volt fan above area of PS board and ran unit thru Polk LSI9s for 2 hrs with enough volume to fill my ~ 24x24 room. No problems (Right ch slightly lower volume than Left).
Next project is a Kenwood KR-2090 Receiver with crackly controls and a misfiring phono stage. CD input to Aux gives no discernable distortion. Anyone with a schematic?
Thanks.
Mort
Alesis RA150 burns power resistorHide this!Advertise here!
Schematic for Alesis RA-100... Ha! Alesis doesn't have it!! crispycircuit Solid State 0 22nd February 2010 10:16 PM
lm4780 Zobal resistor burns immediately on Power ON kuldeepsingh Chip Amps 22 2nd August 2008 01:43 AM
Alesis RA500 Power Amps x2 Tenson Swap Meet 3 2nd February 2008 11:28 PM
Philips cd880 player channel dead, resistor burns out canuck Digital Source 1 2nd September 2004 11:38 PM
Alesis ADAT Power supply TTLHARMNIKDSTN Digital Source 0 10th June 2004 03:04 AM
