Crown DC300A Repair/Restore
Old 10th January 2014, 07:24 PM   #11
rfitts46 is offline rfitts46  United States
thanks Indianajo....will copy and place in my manual. Alot of good info there.
Old 11th January 2014, 01:06 AM   #12
New nubs on power rocker switch. Now will machine two brass fasteners similar to what the OEM used. Will swage these to the steel bracket holding the rocker switch.
Old 11th January 2014, 11:30 PM   #13
keith721 is offline keith721  United States
If you haven't read Tom Wait's DC300A rebuild thread yet, it could possibly be helpful in your efforts.
Old 18th January 2014, 06:56 PM   #14
Power rocker switch is complete. The holes in the switch were opened to .110" which will accomodate #4-40 screws. The two holes in the metal bracket were threaded #4-40. The heads on the screws were reduced until they fit in to the counterbore. A 1" long screw works perfectly no shortening required. Switch operates and light works.
Initial power on confirms that channel 1 IOC light comes on and channel 2 operates as said by the previous owner. The channel 1 power board is missing the two driver transistors and two power transistors. Also missing two of the original transistor insulators. They are made out of a material that looks metallic. Does anybody have two of these available?
WThe four 2N6306 transistors to be used as driver transistors have been recieved.
Will start shopping for power output transistors MJ21194.
Can someone guide me through what checks can be made on the power board once it has been determined that the whole board is populated?
Old 18th January 2014, 08:01 PM   #15
missing R131 and R138 on cnannel 1 as well.
Old 18th January 2014, 10:42 PM   #16
the non operating output board has a white wire coming from the DCA board that terminates at an emitter of an output transistor while the operating channel output board has this white wire going to the base of the driver transistor.
File Type: jpg marked up channel 1 power board from amp.jpg (661.5 KB, 307 views)
Old 18th January 2014, 11:01 PM   #17
I am shopping for 20ea MJ21194 to be used as output transistors. If anybody has a set with same date code please send a response
Old 19th January 2014, 02:21 AM   #18
jackinnj is offline jackinnj  United States
jackinnj's Avatar
If you prefer, I have a few hundred MJ15003G matched.
one further thing I would do with the Crown DC-300 is bolster on more heat-sinking with aluminum fins.
Old 19th January 2014, 11:43 AM   #19
This was off of T Waits thread on resurrecting a Crown DC300A, the15003 are seriously compromised at the supply voltages available from this amp. 21193 would be much better in the higher voltage region of SOAR. The extra current from the 15003 is of no advantage.
Old 19th January 2014, 03:57 PM   #20
can I use NTE QW118-25 - 1/4W 180 OHM 2% Metal Resistor as a replacement for the carbon film resistors used as the driver base resistors on the power board?
Crown DC300A Repair/RestoreHide this!Advertise here!
Resurrecting a Crown DC300A TomWaits Solid State 479 31st March 2017 08:22 PM
crown dc300a krmaudio Solid State 3 29th January 2010 08:54 PM
Crown DC300a Repair Questions DogStone Solid State 8 23rd November 2009 03:41 AM
Crown DC300A Sheggy Solid State 4 3rd July 2008 01:52 PM
Crown DC300A Please Vote! TomWaits Solid State 45 21st September 2006 07:18 PM
