are K2, K3, .... Kn in phase or out of phase (random phase angle) when produced by two identical amps which are fed with same sine signal. If identical amps are paralleled, will distortions become smaller ? Greetings, Bernhard |
#2 |
No, I don't think so. But I'm not 100% sure.
Noise is random |
#3 |
Distortion is not remotely random, noise is entirely random.
Induced noise, e.g. hum, ripple, crosstalk is not random. THD is the sum of noise and distortion. If amps are paralleled, theoretically thermal noise is reduced. Output stage distortion is usually related to output current, and paralleling amplifiers will reduce output stage distortion. |
#4 |
Thanx,
so will only parallel amps reduce distortion or also paralleling output devices Are separate feedback loops necessary ? I read that some bridge configurations will lead to distortion cancellations of even or odd orders (only). Why ? Besides parallel DAC chips, I wonder if it is possible to synchronize sine generators as ICL8038 or stuff like that, to reduce distortion. And op amps... Bernhard |
#5 |
If you have two identical, non-linear amps which have a symmetrical non-linearity, you can feed signal S into one and signal -S into the other and subtract the outputs to cancel the distortion.
If the non-linearity is not symmetrical it doesn't work. |
#6 | |
#7 |
That's an interesting question!
I don't know. |
#8 | |
Erm.... I think you've got this the wrong way round. Balanced topologies cancel asymmetric distortion but cannot cancel symmetric distortion. By using a balanced configuration the asymmetric distortion is the opposite in the other channel, so they are symmetric in this sense, which is why they cancel. Even order distortion is assymetric, odd order distortion symmetric. |
#9 | |
Account Disabled
I tend to think distortion (as induced by component or design) isn't random. For example, running an A/C signal through a diode should always yield you a half wave, which in itself is distortion. |
#10 | |
The one and only
intermodulation go away in a like fashion. |
| Random Noise Generator | dmongrain | Swap Meet | 0 | 30th January 2009 11:13 PM |
| Some random IC for sale.. | sachi | Swap Meet | 1 | 23rd January 2009 05:03 AM |
| Random electrocution? | bob_v5 | Everything Else | 20 | 8th February 2008 04:06 PM |
| Random horn questions | e-side | Multi-Way | 5 | 20th July 2006 10:48 PM |
| Random Popping | ShinOBIWAN | Solid State | 5 | 2nd May 2005 04:21 PM |
| Page generated in 0.10929 seconds (76.98% PHP - 23.02% MySQL) with 11 queries |
