OPA445 - Alternatives available?
Old 28th December 2013, 03:09 PM   #1
Kay Pirinha is offline Kay Pirinha  Germany
Default OPA445 - Alternatives available?
is there any more economic opamp available which is comparable to Burr-Brown's OPA445? It should feature FET inputs and an extended supply voltage range.
Otherwise, is there any workaround to give extended output swing to a common, cheap FET input opamp?
Best regards!
Old 28th December 2013, 03:23 PM   #2
DUG is offline DUG  Canada
OPA551 goes to +/- 30V
But more output current.
Doug We are all learning...we can all help
"You can't stop the signal, Mal. Everything goes somewhere..."
Old 28th December 2013, 04:55 PM   #3
jcx is offline jcx  United States
what V,I is needed? - LTC6090 is a 140 V high Vsupply CMOS op amp but only smt as usual for new parts today
for audio power TDA7293 takes higher Vsupply than most chip amps
if only increased output swing is needed then bridged outputs double the output V
OPA445 - Alternatives available?Hide this!Advertise here!
7591a Alternatives wrenchone Tubes / Valves 16 4th June 2009 06:34 AM
need replacement part opa445 opa551 opa552 prorms Solid State 0 28th October 2008 11:08 PM
Is a OPA445 AC stable with 100% Cap feedback at HF? Fanuc Solid State 0 30th July 2007 10:07 PM
LM386 alternatives? ainami Chip Amps 8 17th September 2004 04:20 PM
High power Amp with OPA445 Dj BASS AMP Solid State 5 6th August 2004 03:41 AM
