Hey Os, do you think these new ips boards will work with the old mongrel amps? Still happily running the AX1.3 with your PB120 boards. Thinking the gla might be nice to try.
Hi OS... can you adopt SMT 1206 parts for the IPS to keep the board size as small as possible? I think this is important if we are going to mount these boards on the back of the case as you suggest.
76.2 X 76.2mm ... not small enough ? 3" is tiny !
I know many like SMD , but where would I get that 220u NP cap (SMD ?)
PS - the front of the case is also a option , leaving the rear for AC/in-out.
OS
SMD only for resistors, ceramics and small signal transistors. Electros could be through hole
With SMD ... I could most likely do all the resistors , small PS decoupling.SMD only for resistors, ceramics and small signal transistors. Electros could be through hole
VAS main devices , silver mica's , and that dang big electro would
remain through-hole.
Maybe <50mm X 76.2mm would be the net result.
(below) is the 76.2 X 76.2mm pcb.... just a little larger than a credit
card ... printed it out , fits in the palm of my hand.
Any case worth its salt that could accommodate these large amps
would have 10-15" interior width (250-375mm).
This would leave 4 -8" extra as 2 IPS's would use 150mm. Front
panel mounting would also be a option.
Most do not have SMD soldering equiptment ... for a commercial
venture .. I WOULD go for at least a partial surface/through-hole
endeavor.
OS
Today i have trim these resistors R16,R13 to take the recommended VAS current 7,1mA-8mA.
So new values for R16,R13 are 560R.
With this value(R16=560R) Vr21=1.1V SO I VAS=V/R=1.1V/150R=7.33mA.
I have change value of R18 also.
New value for R18=22k so Vr18=79,2V I=V/R=79,22/22.000=3,6mA.
I have a small test on digital oscilloscope also,and ONLY a burned 10R .😱
Zobel network.😎
I have an alternative IN board in stand-by.🙂
Thimios.
Zobel network.😎
Thimios.
I think those old ones use the same V+/- PD+/ND- and ground scheme.
These are set up for EF3 ... lower VAS I. Run em' hot (7-8ma) and
your old EF2 would also "sing" !😀
PS- NFB would also have to wired - it's separate now.
OS
Zobel network.😎
Thimios.
Is the last pix (CFA-X) vssa ?? Next one ... 🙂
OS
You ask me?😎😎
OS
Ha ha ha i am confused a little ...
I will try to find schematic for this but i haven't any non polarized capacitor
Two capacitors back to back ? may be....
Thimios.
this is my progress of so far... I have some questions about CFA-X
1)Capacitors C5-C6 must be nonpolar?can we use single polarity electrolytic caps?
2)what alternatives can we use instead of ksa992-ksc1845?
3)do transistors Q1 and Q2 have to be matched ?
1)use 2x2200 back to back for each of this.
2) 2sa 970 or 2sa1015-2sc1845 or 2sc1815
3)yes.
Good luck.
Nice work thimios.
Hopefully we will have a few different versions soon with listening test so we can stop the Madness of new versions every day! I have no idea what country you are in but you do some nice work and seem to be almost as fast making working models as OS is at creating new versions and updates.
Perhaps we can settle on a few versions soon and have some group buys of boards from someone on each of the continents.
Thank Kindhornman, i live in Greece.Nice work thimios.
O dear just now i see that you are an Waveguide & loudspeaker designer!
My congratulations.
Thimios.
Nice work thimios.
Oh , give me a break ...😛
HERE is the goal.
-All my previous VFA designs. - almost done (Wolverine -SYMASUI )
-A new VFA (the spooky leach) ... never designed one.
-The 2 new CFA's (NAD /CFA-X)
-successfully using the hawksford with a EF3 ... did this before ,
but on a EF2 .. "ran out of gas" under load. 🙁
After the "symasui" , only one more topology left ...{the folded
CASCODE}.
With these 6 IPS's we will cover just about all the major class AB
input stage/VAS combinations.
Everyone should be able to find some "magic sound" in one of them.
You get sick of one "magic" , choose another without redrilling/major
rework -waste.
DIY'ers like to "tinker" (I do !😀 ) , this setup facilitates this.
PS - I've seen other threads go for month's ---> year before they get refined performance.
Some still have issues long after the group buys/prototypes. NOT here !!
OS
Agree Agree Agree!Oh , give me a break ...😛
HERE is the goal.
CASCODE}.
rework -waste.
OS
I have listen this amplifier a little but i come for 2nd channel instantly!
Congratulations OS.
Thimios.
Any chance of getting the gerber files for at least the output boards? I haven't had much success at etching my own and board houses are getting very inexpensive. I would love to have a few of those output boards made so I can play along. Please, please please. 😀
Blessings, Terry
Blessings, Terry
I would think that it would be practical to do a group buy on the output boards alone. Those wont be changing.
I would rather just order some direct. Group buys usually involve a lot of time for gathering names, payments, shipping to the OP then shipping to the buyers. Sometimes takes several weeks.
- Slewmaster - CFA vs. VFA "Rumble"
