Slewmaster - CFA vs. VFA "Rumble"
Actually , it is better to use any >60mhz Ft for the pre-drivers.
340/350 are quite slow <20mhz Ft.
I only use 340/350's for bias generators and cap multipliers.
Here , just Hfe (current gain) matters.
Even MPSA92/42 would be better here. Any
TO-92 or 92L will also work here - not much current , but
watch the pinouts ... (ECB vs.EBC).
You want any >60mhz and >1W device for these pre-drivers.
- 30mhz and 100W for drivers , 30mhz for outputs.
PS - 3 pair OPS's have been run successfully with just a 1837/4793
pair as driver (To-220). BTW , the 1837/4793 toshiba's would be overkill (20w) ...
but also a good pre-driver choice - fast / 100mhz Ft.
Edit- you realize any of the slewmaster VAS's can be biased down to 3-4ma.
At this point , any of the fast TO-126 packages can be replaced with TO-92/L.
Only <1W at 3.5ma .... at 5.5ma+ almost 2W , larger package here.
OS
The MPSA92/42 are listed as 625mW, 50 MHz devices. Will they OK for the predriver stages?
Simulator only shows .2 watts at the pre-driver , .32 W ...even with loading.
Drivers are 1W at rest , 10W with a 2R output loading.
92/42's should be good , as the pre-drivers are affected minimally as loading
increases.
My OPS .... I have never detected any heat at all at the 1381/3505's . The
Harmon-Kardon 680/990 both use small footprint <1W devices , as well.
You should be fine , watch those pinouts.
OS
(below) Slew OPS will easily handle a 3.2ma Vindicator VAS I.
Either use 330R for R48 , or adjust R49 to about 150R (the trimmer).
As you see , I just raised R26/R27 to 220R.
Like all the other slewmaster IPS's (with zeners) , R15/16 need to be adjusted
to the rails AND be a higher wattage.
With these values , and less than 60V rails .... I think even to-92's will
have enough derating .
OS
I think it will tamper the most sensitive part of the circuit.
I will , but not any worse than what anti-parallel diodes would do across the
LTP collectors.
(below) T13 or 14 saturate , forward bias T25 .... causing T26 to conduct turning
the LED on.
Short of clipping , the reverse leakage of t25 might affect the LTP.
I've noticed on lower Z circuits like this or the Kypton V .... no issue.
On a higher Z current mirrored input section , reverse leakage is a
bigger issue (like a "blameless").
Here is better one - Clip Indicator (LED) for any power amp
Runs right off the output (real low Z).
Another - Project 146
Clipping Indicator For Audio Amplifiers Circuit Diagram
These all assume you KNOW at what point your amp clips and references
the actual output waveform to a rail. At least this does not require input
stage "meddling". 😀
OS
Is the value of CXa/CXb on the Vindicator V(fa) critical? I'm not able to source film caps of 39pF. Only 33pF/47pF available. 39pF is however available on ceramic/ceramic MLCC types.
Hari
Actually, try the Groner TIS without them initially.
It was mentioned that this TIS has peaking >7mhz. I did not see this
in any simulation including using a tian to probe the TIS independently.
I decided to at least include Cxa/Cxb as an option because this "peaking"
was mentioned by both Groner and Kleinschmidt.
The main 68-82pf local compensation (C11) might be enough (according to
both the bode of the TIS and global simulations).
This is a new design - bear with me ... 😀
OS
OS
OS, we'll more than just bear with you 😀 You have been a veritable gold mine for us diyers 😎 I'll leave them out initially and see how it sounds, then I'll take a call.
Hari
I'm planning to finish two slewmaster monoblocks for subwoofer use. I have two working spooky ips and the ops just need drivers and output trannies before it's ready.
Each slewmaster will have a 2x55V 800va transformer, so it should give 78-80v rails.
I want to use these subwoofers Dayton Audio UM15-22 15" Ultimax DVC Subwoofer 2 ohms Per Coil
Will 5p 0302 and 0281 be up for the task, or would you use MT200 devices for this project?
Full "arcwelder" mode - 5 pair MT-200.
Do you have the newest V3 OPS ?
OS
