I think I'm seeing a pattern here. You're from moonshine country. Valery's from Vodka country...
Yes , but now it's legal. Local distilleries found out about my process control "magic" ,
I built them a PC controlled process (free samples now).
I wish I knew the arduino then , shiners in the woods would have "21st century"
distillation.
My grandma (from the Ural's) always had the Vodka under the sink (medicine).
US Vodka gives me a headache - legal local moonshine = heaven (NO after-effects).
As far as a pattern - It helps to elicit that "outside the box" thinking. 😀
OS
What are you lacking for parts still? I think I forgot to send voltage regulators with that last shipment.
For my 5 pair main stereo boards , the 4.7R stoppers @ 1/4 w are good - but I have
only 13 of those. I ran the math - the 5 pair stoppers will see .21W @ 2R clipping
with NJW0281/0302's.
The MT-200's are another story - lower beta , they will need .5W/4.7R + on the sub amp.
The taps are cool - I never seen one like that 6-32 (fluted ?).
My "bench test" now - just 40-0-40V with the wolverine .... test all 6 OPS's (drivers set for 1 V vbe) and jury rigged feedback.
Then , with KNOWN good OPS's set to a known current - plug in the "spooks".
Still need the extrusion for the sub - BTW , your plates fit perfectly.
OS
OS
Those 4R7s are 1 watt small frame if they are the ones I think I sent. It should say right on them. I don't trust them either. I'll send some real ones down.
All those taps are designed specifically for aluminum. That #6 3 flute one works great for thick metal. That M3 one that looks like a thread chaser is great for sheet metal.
Oh , in the new bag ? Nope - lowest value in that bag is 47R.
Many fell out of their tape strips - those are also 39/47R's.
So , I have 13 1/4W 4.7's - need 7 more - no 1/2w's at all.
OS
I must have missed them. I thought they were in the first box.
All is treasured and golden to me - (below) .. I measure each group and even
sort the "orphans" - No missed parts/mislabled ...or waste.😎
OS
OS
You sure shrank that pile down! That was a mess of components.
Oh no , the pile is bigger - but all sorted and tested like that.
No unlimited resource like dear friend Jay.
Actually used about 3/4 of everything. Have all 6 OPS , 2 spooks , 1 wolverine
DONE - ready for "magic smoke" 😀.
PS - even dived into my original stock. 6 amps (and protection) take a lot of parts !! 😱
OS
I have finally figured out everything with regards to the credit note (got a letter from them today). So I will place an order for snap-in caps in the nearest days.
Thank you , dear friend Val ! 😎 Hey , can I clone your bootstrap VFA ??
I'll put yer name on it ! 😀 ( it is a good design - servo it and the "thump" will be gone)
OS
Modular Supply
Does anyone see any issues with this supply?
EDIT I just saw the inverted diodes.
let's see ... 😕
Multi-pitch 4 cap , to-220 diode chassis mount , bleeders , snubbed ... with
ability to use external bridge.
Very fat traces- 20a/1oz.
WAY better than Ebay cheapo's. 🙂
OS
OS
21'st century amp ?? (hard work) ...
So many choices - like Walmart ... 😀
I decided to go with Adcom's grounding setup. (below)
"Buried" my star ground near the trafo - had to split the trafo AC out to the 2 bridges with the euroblock.
Will have it wired to the point of initiating a "controlled startup"(PS) with the Arduino.
The taps were VERY good , especially that "fluted" one. Everything fits 🙂 .
The heatshrink is strange - glues itself to the wire ? Better quality stuff than in
the hardware store/radio-shack.
This will be tight like the Genesis stealth amp (but way cooler).
OS
OS
I think I'm going to do another with fuse holders for the outputs. Definitely larger though.
Maybe for a testing rig PS , but most have the fuses on the OPS ? Why be that
redundant ?
OS
redundant ?
OS
I've just finished Valery's CFA-CFP. No on board fuses. Personally I think fusing should be at the supply anyway. Why not protect the supply from a wire that has gotten chafed or pinched somewhere? It's my automotive background kicking in again.
It's looking good so far.So many choices - like Walmart ... 😀
OS
Yes that heat shrink has glue in it. No repositioning after. It's rare to find adhesive shrink tube that's flexible.
I don't think the supply would feel a thing. 😀 I actually pinched/ shorted these
big PS's out accidentally .... the discharge usually partially melts the wire while blowing
the main AC fuse. Even that little 10A tabbed bridge PS survived this a few times. 😱
OS
I've always been taught that fusing belongs at the source. Fuse again where it splits for distribution. But then again quite a few things are different in audio than the rest of the electrical world.
- Slewmaster - CFA vs. VFA "Rumble"
