Push-Pull using only N-Channel MOSFETs
Old 25th December 2003, 07:24 PM   #21
Kashmire is offline Kashmire  United States
Now the secondaries of the transformer have been moved so that the MOSFETs work as a source-follower. I'm a bit uncomfortable running the transformer secondary through the bias resistor, so an AC coupling cap can be added on top and bottom (example bottom capacitor shown).
The bias is uncontrolled; the 28k and 2k resistors give about +2V on the base of the FETs. The bias current (~1mA) flows through the transformer secondary.
I didn’t draw the grid stoppers, ect … so don’t start being picky.
Notice that voltage variations in the power supplies will cause DC offset.
My next installment will study joining the power supply, to a single bipolar supply. Once that’s done, all that’s left is establishing DC bias control, and maybe a bit of local feedback.
Old 26th December 2003, 02:29 AM   #22
SkyChu is offline SkyChu  Taiwan
Here is other links of CSPP , If you known Japanese:
http://www.ne.jp/asahi/evo/amp/CSPP/2SJ18.htm
http://www.hinocatv.ne.jp/~s_suzuki/...4/J114CSPP.htm
Sky Chu
Old 26th December 2003, 11:30 AM   #23
subwo1 is offline subwo1  United States
subwo1's Avatar
I just decided to see if anyone has tried using a biased mosfet connectred from the gate to the source of each output mosfet to stabilize the bias. I simulated it a little, but don't know if it really works.
USMPS
http://groups.yahoo.com/group/switchmode/
Old 26th December 2003, 12:34 PM   #24
Circlotron is offline Circlotron  Australia
Circlotron's Avatar
Subwo1, like this?
http://www.diyaudio.com/forums/showt...5226#post35226
Best-ever T/S parameter spreadsheet.
http://www.diyaudio.com/forums/multi...tml#post353269
Old 26th December 2003, 12:42 PM   #25
Circlotron's Avatar
Default Kashmire has my disease. Buahahaha!!
This way works really well! Good cct for mentally chewing over too. http://www.diyaudio.com/forums/showt...658&highlight=
Old 26th December 2003, 03:58 PM   #26
subwo1's Avatar
Circlotron, yes, that does seem to be the type of thing I was thinking of. Just out of curiosity, would you have a diagram?
USMPS
Old 26th December 2003, 05:43 PM   #27
OK – Time to join the power supplies. Sorry Circ’.
Going back to the first schematic, look at just the biasing scheme. If a resistor ladder is used, +4V can be applied to the MOSFET gate-to-source on both N-channels (see schematic below). An op-amp servo loop can control the middle of the voltage divider, in order to maintain zero DC offset at the output.
The op-amp strives to force the inverting input (-) to match the noninverting input (+). Since the noninverting input is connected to ground, the op-amp modulates the bias voltage on the resistor divider to keep the output at ground potential. Since you don’t want the op-amp to damp the AC output signal, a capacitor is used to set the time constant of the servo loop.
If the power supply voltages drift, the bias current will drift. It may be useful to have an absolute voltage reference for the voltage divider. The second circuit uses a zener diode for reference. This setup will allow for 8 volts of drift in the power supply, while keeping +4V gate-to-source on the MOSFETs.
The next message will be applying the signal to the circuit.
Old 26th December 2003, 06:00 PM   #28
Now to apply the signal. There are multiple options. My first schematic I posted has one method.
The circuit below applies the signal gate-to-drain. The signal appears over the secondary of the interstage transformer at the gate. The circuit is completed by the AC coupling capacitor Cac to the drain.
The AC coupling capacitor is the ultimate in local feedback for the MOSFET, functioning somewhat like connecting a pentode as a triode (vacuum tubes). The local feedback eats up all of the transistor’s available gain, resulting in the system operating in unity-gain. This is called source-follower mode. Therefore, the driver stage will have to provide all of the voltage gain. In this case, somewhere around 15 V/V would work well. I didn’t include a schematic of the driver stage, but I would start with a single-ended triode or triode-connected pentode.
I didn’t draw the gate stopper resistors. I assume 100 Ohms would work. I’d also include some 20k resistors to load the transformer secondaries.
A zener diode (see previous) could provide an absolute reference to the bias resistor divider. Switchable bias resistors could have two settings, “ice cube” and “pottery kiln”, depending on if you want 1A or 2A of bias current. Since this amp could work as class AB, as little as a few mA of bias current is actually required for operation. It would be a very cool amp, but wouldn’t sound that good. This functionality would be very useful, because the amp could run cool for everyday operations (television) and hot for critical listening. This is the one feature that the Zen amp designs don’t have.
Using source resistors (0.25 Ohms) would add a bit of stability and provide some local feedback. I added these to the schematic. In addition, they provide a good place to measure bias current. Another DC servo and voltage reference could be implemented for precise bias current control. That’s overkill for me.
I expect to model this circuit over the next few days.
Old 27th December 2003, 11:20 AM   #29
Circlotron's Avatar
Kashmire, I see your brain is really running hot!
This is what I was talking about the other day. Note the negative end of each bias supply is referenced to it's own fet source.
Old 27th December 2003, 11:32 AM   #30
Magura is offline Magura  Denmark
Magura's Avatar
And then again...SOZ is actually sporting the option to have a moderate dissipation for everyday use and cruel dissipation for ...hmm...NICE use
All you gotta do is to build it with 2 sets of secondaries on the trafo, if im not mistaken it will run as low as 8 volts, thats not too bad. Then you can switch in between those two settings.
Magura
Everything is possible....to do the impossible just takes a little while longer.
www.class-a-labs.com
Push-Pull using only N-Channel MOSFETsHide this!Advertise here!
Phase inverting one half of a push-pull parrallel channel before recombining? Test Electrix Power Supplies 3 23rd March 2009 07:04 PM
push pull chainenoble Subwoofers 17 28th June 2006 04:35 AM
modify parallel push-pull EL84 to single push-pull chungtat Tubes / Valves 12 3rd November 2005 11:25 PM
Push-pull amp with OP piney Solid State 1 28th March 2005 02:34 AM
Double push-pull versus single push-pull jraraujo Tubes / Valves 19 19th October 2002 12:23 AM
Copyright ©1999-2017 diyAudio
